Old 04-24-2006, 10:43 AM   #1816
PRO KIT
DAVE BERNATH is offline   Reply With Quote
Old 04-24-2006, 11:04 AM   #1817
macnkitty2002's Avatar
front CNC B-blocks, upper CNC steering brace.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-24-2006, 02:04 PM   #1818
SavageSYNTH25's Avatar
Send a message via AIM to SavageSYNTH25
Upper and Lower Aluminum front "B" Blocks (Trust me, you'll never run the A. It makes the car too twitchy)
Cradock Brakes
XTreme Aluminum Rear Hub Carriers
Aluminum 1 degree rear Anti-Squat
One Piece Motor Mount
Big Bore Shocks
TKO Ceramic diff, drivetrain, and clutch bearings
That's about it!
SavageSYNTH25 is offline   Reply With Quote
Old 04-24-2006, 08:52 PM   #1819
arghh's Avatar
just change the plastic front lower arm holder to 7075 alloy B plate.. thats all.. the others are bullet proof already
anybody try hard shock spring..how performance..??
arghh is offline   Reply With Quote
Old 04-24-2006, 08:55 PM   #1820
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
... and for someone about to receive a Factory Team version ?, any extra upgrade i must do before racing ?,
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-24-2006, 09:00 PM   #1821
ryan6682's Avatar
Micors.
How many of these items that were listed above. are on the buggy I am getting from you. I wouldnt know whats been changed and what hasnt as I havent had any experince with this buggy
ryan6682 is offline   Reply With Quote
Old 04-25-2006, 07:04 AM   #1822
i bought the hard spring set for the stock shocks, as in the small ones. they work great, in fact, i put the hard ones on the rear and the blue ones on the front. it works great for the bumps and jumps.
Losi Rock Rey
Old 04-25-2006, 07:06 AM   #1823
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
the cradoc brakes, 1 degree anti squat plate, one peice motor mount and, has avid revolution bearings.
i have never broken a rear hub so i dont think he alunimum ones are needed. only thing i would change on the car is the lower and upper b blocks.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-25-2006, 02:44 PM   #1824
thanks,
The only thing I'd recommend for sure is Ceramic bearings. The ones they include seem fairly cheap, I only got one race on the stock ones before they needed to be replaced. Go ahead and drop in some TKO Ceramic bearings.
Old 04-25-2006, 02:48 PM   #1825
For medium sized tracks with a few large jumps, the stock Red (BB) springs just arent right. I've messed around with 30-70 wt. oils, and the car either gets really loose on landing or bottoms out bad on landing.
I finally ended up running the Mugen Grey (Stiff) springs, front and rear. With the right shock oil, the car drops down soft (not bouncy, like the Red springs) but doesn't bottom unless you completely overshoot the jump.
Old 04-25-2006, 02:56 PM   #1826
Default Diffs
I need a detailed answer on what going up and down with diff oils on an 1/8 does for the handling. What it does for the front, center, and the rear.
RobertH is offline   Reply With Quote
Old 04-25-2006, 03:06 PM   #1827
Higher viscosity: "Locks" the diff down more, which basically means the diff won't slip as much. If you go into a corner and lift a wheel, the car is more likely to keep accelerating instead of sending all power to the free-spinning wheel. The heavier fluid may create a slight push as well.
Lower viscosity: The diff feels "loose", and the diff slips easily. This would help the car rotate in the corners better because the diffs are "freer" but if a wheel is lifted through a corner, you may loose momentum because all the power is being transferred to the free-spinning wheel.
I would run 5ooo wt. oil in the front at all times. This helps the car rotate well in the corner, but if you lift a wheel into a fast corner it doesn't "unload" very bad.
Run a slightly heavier oil (7ooo wt.) in the center. If the front tires are "balooning" down the straightaway, run a slightly heavier oil in the center.
In the rear, I would run 3ooo wt. oil. This will help the car rotate out of the corner. Sometimes, especially on a loose track, I'll move up to 5ooo or 7ooo wt. oil in the rear. This "locks" up the rear end and helps it slide into the corner (which can be helpful if you want to hit the throttle, slide into the corner, and straighten it out instead of rolling into the corner and powering out (which is where you would want the lighter oil)).
Hope this helps!
Old 04-25-2006, 03:11 PM   #1828
thanks for the info, that helps me too!
Losi Rock Rey
Old 04-25-2006, 03:12 PM   #1829
No problem!
Old 04-25-2006, 07:59 PM   #1830
arghh's Avatar
so ur diff is f5 c7 r5 & f5 c7 r7 correct..the rear diff got the heavier oil.. really headache me about diff tuning.. what about front heaviest like 7f 5c 3r..or 5f 3c 1r..??
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
