Old 04-04-2006, 07:20 AM   #1771
macnkitty2002's Avatar
i hope so!
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 04-05-2006, 07:09 AM   #1772
DRKWNG's Avatar
Has anyone tried the new aluminum center diff mount?
does anyone else's center diff move slightly(front & back)? I was wondering if the aluminum center diff held the center diff tighter.
DRKWNG is offline   Reply With Quote
Old 04-05-2006, 07:12 AM   #1773
SpeedBump57's Avatar
The center diff has moved back & fourth in every car I have owned. I use this as an advatage. You can center the spur on the clutch bell if you shim the center diff just like you would shim the front or rear diff.
SpeedBump57 is offline   Reply With Quote
Old 04-05-2006, 11:18 AM   #1774
GeneralG's Avatar
Send a message via AIM to GeneralG
Is it worth upgrading to the FTE specs for this buggy? I've already got the X1CR when it first came out.....
www.gsairwerx.com
GeneralG is offline   Reply With Quote
Old 04-05-2006, 11:23 AM   #1775
DRKWNG's Avatar
Speedbump, When you shim the center diff where do you add the shims? Between the diff and the bearing or between the bearing and diff mount?
Or is there a different way I'm not thinking of?
Old 04-05-2006, 11:25 AM   #1776
DRKWNG's Avatar
GeneralG, the new Brakes, Shocks and Shock Towers are all worth investing in.
Old 04-05-2006, 05:22 PM   #1777
DRKWNG
Between the bearing and diff mount. I cut about a 1/8" out of the shim and slipped it over the outdrive cup.
Ditto!
"GeneralG, the new Brakes, Shocks and Shock Towers are all worth investing in."
Also the only upgrade I see that is a must for the FTE is the new front upper plate they offer.
Old 04-05-2006, 05:27 PM   #1778
what, the stock CF one is bad or something? i haven't crashed mine yet, but it the upper plate prone to snapping?
don't forget the King Headz plate, that looks better than the Jammin' one in my opinion. good price too.
http://www.carolinasrc.com/Webstore/...idproduct=1399
Losi Rock Rey
Old 04-06-2006, 07:35 AM   #1779
DRKWNG's Avatar
I've snapped two upper plates. I put the King's head one on mine.
The aluminum upper B block for the front is a good buy as well. I've seen a couple of the plastic ones break but it was only in very bad crashes.
I was at Leisure Hours and a Jammin went full speed into the cinder block wall. It ripped off the front wheel, broke the plastic upper b block, lower a arm, and bent the universal. When it hit the wall it looked like the entire car was destoryed. I was happy to see that the jammin held up very well.
Old 04-06-2006, 07:52 AM   #1780
i might have to get the King Headz one then.
Losi Rock Rey
Old 04-07-2006, 08:00 AM   #1781
DRKWNG's Avatar
I does look cool too.
Old 04-12-2006, 10:49 PM   #1782
arghh's Avatar
look at the losi 8ight buggy.. no front upper a-arm..only chamber link like on rear arm.. any comments..?? do u think it could be done to all buggy that using c-hub..?? actually what are the advantage using front upper a-arm
arghh is offline   Reply With Quote
Old 04-12-2006, 11:45 PM   #1783
Aaron Waldron's Avatar
Advantages - Stronger
Disadvantages - Binds under full travel.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 04-13-2006, 12:28 AM   #1784
yamrace's Avatar
Anybody find out which is the best shock boot for the big bore shocks? I am building my first 1/8 scale buggy and don't like the fact that the shocks don't come with boots to cover the shock shalf like the rest of the buggys do.
yamrace is offline   Reply With Quote
Old 04-13-2006, 09:08 AM   #1785
Gary NJ's Avatar
I think the Kyosho boots are the best combination of quality and cost. Fit the big bores perfectly.
Gary - GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
