Old 03-27-2006, 03:06 AM   #1756
dazyz's Avatar
Originally Posted by tmaxxking
here is how my set up works ..
like a real car would . i guess pivot is a better word to use the slide ..
when the front tires are locked and the rears are still in motion
the power will transfer to the wheels that are still moving
forceing the front into the turn .
as for fiber disc pads you use just steel pads ..
If you are already braking then there is no power only momentum. ???
dazyz is offline   Reply With Quote
Old 03-27-2006, 04:59 AM   #1757
macnkitty2002's Avatar
thanks.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 03-27-2006, 07:31 AM   #1758
Default sticking brakes
I have the same problem with my stock brakes sticking. I tried putting diff oil on the springs between the pads but it seemed to stick more. But i'll try to add diff fluid on the cam and back of the pads and let everyone know.
Anyone else have any suggestions on a fix? I've lowered my brake travel on my radio to a point where it won't stick any longer but braking was significantly reduced. Has anyone shaved the threads off the screws that hold the pads or use a different brand (maybe kyosho or mugen) screw that doesn't have threads?
rai
rai13 is offline   Reply With Quote
Old 03-27-2006, 08:13 AM   #1759
DRKWNG's Avatar
Brakes are such a Pain in the A$$, I have mine working great now but I have the fiber disc's and steel pads. I could never seem to get them working right when I had the stock setup or the metal fiber pads. After hours and hours of tinkering I got them working but never great. I would say try whatever you think will work and don't be afraid of the dremel.
Mac-n-Kitty, I have a buddie who had the brake pad sticking problem. He took some Knuckle Arm bushings from a Touring Car and dremeled out the pads to were the bushing fit perfectly and said it solved the problem because the Bushing slid very easily on the pad achor bolt. He didn't remember which bushings he got though.
DRKWNG is offline   Reply With Quote
Old 03-27-2006, 08:34 AM   #1760
do you think that there is a bearing the same size as the bushing?
Losi Rock Rey
Old 03-27-2006, 06:38 PM   #1761
SpeedBump57's Avatar
Mattman send me your e-mail as I don't have it like I thought and it is blocked in here.
SpeedBump57 is offline   Reply With Quote
Old 03-28-2006, 06:52 AM   #1762
DRKWNG's Avatar
I don't think they make bearings that small. I think the Bushings were from a T3 or T4 touring car.
Old 03-28-2006, 06:54 AM   #1763
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
a bearing would serve no purpose as it would not spin. it would just be getting pulled side to side, so a bushing would be better
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 03-30-2006, 05:23 PM   #1764
schmelme's Avatar
Aaron do you know if the shock boots on the factory team car are available seperate. The part listing lists the whole shock.
Those will last way better than what came on the pro car.
schmelme is offline   Reply With Quote
Old 03-31-2006, 08:52 AM   #1765
schmelme I have been using ballons for about two years with no problems. You can get 100 ballons in four different colors for about 3 bucks. They are the ballons you can twist up to make different shapes.
Old 04-01-2006, 06:51 AM   #1766
Bad Mika's Avatar
Hi Guys !
Appreciate if anyone could help enlighten me on the X1-CR latest news...
I've seen a 2nd version of shocks with the rear shocks longer than the 1st edition. And for the latest, Jammin came out with the Big Bore shocks.
Question is, is whether the Big Bore shock (this is the latest i assume...) rear shock length followed the 2nd edition shocks or it went back to the same length as the 1st version ?
Many Thanks !
Bad Mika is offline   Reply With Quote
Old 04-03-2006, 01:42 AM   #1767
arghh's Avatar
1:8 offroad buggy.. seem this is big business nowdays..kyosho, mugen, sacker, dirt pro, hot bodies, lightning pro, mayhem, crono, bergonzoni, caster, cen matrix, jammin, gs, hobao, xray, sidorf, o'donnel.. losi still on the way.. and serpent 401 maybe the latest.. really very tough to choose
arghh is offline   Reply With Quote
Old 04-03-2006, 05:16 AM   #1768
What?? Serpent? where did you hear this?
Losi Rock Rey
Old 04-03-2006, 06:53 PM   #1769
arghh's Avatar
hahahaa.. michael salven, serpent official team driver loughing and confirm said that's all are aprill foolllll
Old 04-03-2006, 10:30 PM   #1770
xlgraphicspro's Avatar
Man, is that Bad "Engrish" part of the April Fools Joke?
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
