Old 03-21-2006, 04:26 AM   #1741
macnkitty2002's Avatar
but that won't help if the brake pads are getting hung up. i'm about to go back to my stock brakes.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 03-21-2006, 01:34 PM   #1742
tmaxxking's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to tmaxxking
Talking disc
these are the brake disc i run
http://www.kfactoryracing.com/produc...8026&pageNum=1
along with the ofna pads
FEEDBACK LINK
rctech.net/forum/showthread.php?t=106423
tmaxxking is offline   Reply With Quote
Old 03-21-2006, 04:18 PM   #1743
from who can i purchase the K-factory disks?
Losi Rock Rey
Old 03-21-2006, 04:59 PM   #1744
tmaxxking's Avatar
Post ebay
i picked mine up on ebay from the seller rcboys..
http://stores.ebay.com/RCBoyz
contact seller .. tell him what you are looking for and ask him to list them if he has them instock he will..
i think i paid under 25 shipped
FEEDBACK LINK
Old 03-21-2006, 05:44 PM   #1745
do you run the ofna fiber pads that are stock on the X1?
Losi Rock Rey
Old 03-21-2006, 06:11 PM   #1746
tmaxxking's Avatar
Arrow pads
i run these ..
part number 36659 semi metalic pads 2 sets needed
picked them up from nitrohouse
FEEDBACK LINK
Old 03-21-2006, 08:57 PM   #1747
arghh's Avatar
what are actually the best brake.. some time i saw man want very power stop brake that can lock all 4 tyre but some time saw the best brake wont make the tyre from stop rotating (some sort like ABS brake)..
arghh is offline   Reply With Quote
Old 03-21-2006, 09:24 PM   #1748
tmaxxking's Avatar
Talking brakes
i run my front's tighter then the rear . this makes the buggy push the front into the turns and the rear will slide into the turns .
thats how i run my brakes
FEEDBACK LINK
Old 03-22-2006, 02:03 AM   #1749
arghh's Avatar
how this can happen since only the front tyre only have tight brake that may lock the tyre.. how rear tyre can slide
Old 03-22-2006, 05:41 AM   #1750
i agree, the back can't theoretically slide around unless the rear is locked up. however, i think that the front tires are locking up and the car is spinning out, almost like drifting into a turn. that will give the same effect as locking up the rear.
so you only have to use the metal brake plate with the ofna fiber disks?
Losi Rock Rey
Old 03-22-2006, 02:18 PM   #1751
tmaxxking's Avatar
Default ohhhh
here is how my set up works ..
like a real car would . i guess pivot is a better word to use the slide ..
when the front tires are locked and the rears are still in motion
the power will transfer to the wheels that are still moving
forceing the front into the turn .
as for fiber disc pads you use just steel pads ..
FEEDBACK LINK
Old 03-22-2006, 02:56 PM   #1752
thanks.
Losi Rock Rey
Old 03-24-2006, 05:43 PM   #1753
tmaxxking's Avatar
Talking almost forgot
i almost forgot ..
also next time you have your diff plate off..
drop some lube in the diff mounts where the brake cam turns ..
also on the back of the cam that hits the back of the pad ..
tends to get a flat spot .. and stays locked up ..
as i sit here putting a jammin together i have sold ..
it's been sitting a while a few mins and some drops off diff lube the brakes are awesome on the return ..
i use diff oil or a good shock oil as long as it's silicone based it wont come off so easy ..
i do this when ever i clean the beast up .. nitro clean tends to clean too much some times ..
FEEDBACK LINK
Old 03-26-2006, 05:32 PM   #1754
so put some oil where the brake cam sits in the diff mount, and on the surface where the brake cam contacts the plate? what about on the screws that hold the brake pads on?
has anybody tried just using two brake disks, one front and one rear? using the stock units?
Losi Rock Rey
Old 03-27-2006, 12:51 AM   #1755
tmaxxking's Avatar
Default just the cams and back of the pads
just a drop of oil on the cams and the back of the pad ..
and on the diff mount where the cam pivot's
single pads you wont have enough braking power ..
FEEDBACK LINK
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
