Old 03-19-2006, 06:46 PM   #1726
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
how is going to see your breaks when racing? no one
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 03-20-2006, 02:30 AM   #1727
Bad Mika's Avatar
Hi Jamminers',
Not sure if this has been discussed before... but any idea why the X1CR comes with a 48T center gear whereas other buggies ( The M.... car ) comes with a 46T ?
Are there option parts or other brand gears that i can fit in to try ?
Thanks !
Bad Mika is offline   Reply With Quote
Old 03-20-2006, 06:45 AM   #1728
macnkitty2002's Avatar
i think they use a larger spur because the diffs are geared differently.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 03-20-2006, 07:21 AM   #1729
DRKWNG's Avatar
Macnkitty, I had the brake pads you ordered and they worked pretty good. You need to take the stock steel disks and JB Weld them together so you have one thicker steel disk.
I upgraded to the thick Ofna fiber disks and steel pads and they are awesome. They were designed to stop the truggy consistenly and it weighs alot more then the buggy.
DRKWNG is offline   Reply With Quote
Old 03-20-2006, 07:25 AM   #1730
but that still doesn't explain why the pads won't come back off of the disks when the brakes are released. they are getting hung up on the screws.
Losi Rock Rey
Old 03-20-2006, 07:38 AM   #1731
are they getting hung up on the screws or do you have too much play in the pads and the break lever is sticking closed?
Rob Jensen
Old 03-20-2006, 07:59 AM   #1732
they are getting hung on the screws. i have 1mm of clearance in between the disk and the pad. is that too much?
Losi Rock Rey
Old 03-20-2006, 08:59 AM   #1733
no. thats how much clearance i have on mine, but i also use the fiber pads.
Rob Jensen
Old 03-20-2006, 11:10 AM   #1734
...and the fiber pads don't hang up either.
Losi Rock Rey
Old 03-20-2006, 11:12 AM   #1735
nope no hanging up.
Rob Jensen
Old 03-20-2006, 02:28 PM   #1736
the fiber pads are the stock ones, are you sure you're not using the semi-metallic pads?
Losi Rock Rey
Old 03-20-2006, 02:29 PM   #1737
DRKWNG's Avatar
I had the same problem with mine and just ran it anyway because I could never get them to stop hanging up either. I also had the one side of the brake cam shaved down and springs mounted on the brake lever control arms so when I was on the throttle there was no pressure on the pads and they just wore in and worked good (never great). I also tinkered with shaving the screws that hold the pad on and cut a bic pen spring (or similar spring)to fit because it has alot more tension than the springs that come with the kit. They never worked perfect but were better than stock. The thick Fiber disks and metal pads (scuffed a little) work great and I've never had a problem with them since the day I put them on. I know it sucks wasting hard earned money but these are an upgrade with buying. Hope this helps.
Old 03-20-2006, 02:31 PM   #1738
i still think i'll get the CNR kit, it's just too tempting.
Losi Rock Rey
Old 03-20-2006, 03:11 PM   #1739
i meant fiber disk. get the cradoc fiber disk you only need one for the front and one for the rear. and the pads need to be blank meaning just metal
Rob Jensen
Old 03-21-2006, 12:57 AM   #1740
tmaxxking's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to tmaxxking
Talking best brakes to be found
nitrohouse told me to pick up
racers edge k factory hard ventilation brake dics . they look like crossed drilled rotor found on most jap cars .. or bike's
there crossed drilled and balanced ..
k factory part number rcek8026
for pads ofna part number 36659 semi metalic pads 2 sets needed
killer combo stops on a dime ..
he has 8 gallons on his pads and disc's
but it's pricey at almost 75.00
i found the disc's on ebay seller rcboys
and i got the pads from nitrohouse.com
you will need one set of disc's and 2 sets of the ofna pads
say good bye to brake fade for ever
FEEDBACK LINK
rctech.net/forum/showthread.php?t=106423
tmaxxking is offline   Reply With Quote
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
