Old 01-26-2006, 11:30 PM   #1576
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
did a little research and found a set for $19.99 from RCmart.com, it's a HK store shipping will run about $7 or so , can have it for $27 shipped, i think i will order one .
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 01-27-2006, 02:41 AM   #1577
anyone on the bumpsteer question i posted?
knight is offline   Reply With Quote
Old 01-27-2006, 04:08 AM   #1578
krisnata's Avatar
Location: Everybody wants to go to Heaven..... but Nobody wants to die
every car has dfiffernt design so pararel steering link not necessary zero bumpsteer. you have to chek it your self.
press the front part and see wether toe angle change or not and set from there.
when the car enter the turn, all weight goes forward and press the front part. if you set more toe out when press down, then you have an understeer car
krisnata is offline   Reply With Quote
Old 01-27-2006, 01:31 PM   #1579
Panther's Avatar
Send a message via AIM to Panther
Bumpsteer is what happens when the the shock/spring compresses on the wheel while turning. As a result of the the shock compressing is causes the camber angle on the wheel to change thus losing camber angle.
So for example, if I was making a right hand turn, the left front would compress and if the bumpsteer was severe I would lose camber angle resulting in less turn in to the right.
Larger racecars have bumpsteer gauges that they stick on the hubs and measure.
-Seann
Panther is offline   Reply With Quote
Old 01-27-2006, 02:46 PM   #1580
macnkitty2002's Avatar
i thought your camber increased temporarily while your shocks are compressed?
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 01-27-2006, 04:37 PM   #1581
Bump steer is when your suspension compresses the wheels "toe-in"...
Toe-in is how your front tires set in relation to each other when viewed from above
Chamber is how the tires set in relation to each other when viewed from the front or back
Caster is how the kingpin sets in relation to the chassis and can be seen from the side
Kick-up is how the lower suspension arms set in relation to the ground
Absolute zero bumpsteer is and absolute impossability, unless you have a solid front axle with the steering servo mounted to it like teh Tamiya clodbuster, Kyosho mad force, or XTM x-factor, or you have no suspension.... all cars have bumpsteer, some are so little that it has to be seen with guages, while some are so huge that it extremely effects the car....
Chamber changes when the suspension is compressed is called "reactive chamber" and most double wishbone suspension systems have very little or absolutely none depending upon suspension settings......
caster changes during suspension compression are absolutely zero except on cars with single wishbone suspensions that have kick-up built into the suspension mounts.... they have the c-hub built in as a solid part of the suspension arms.... this is only used on some of Tamiyas lowest end models and toy cars..... yet the caster changes are still minimal and the bumpsteer is a much more prominant problem with these models... however Team associated has an on-road suspension for pancars that changes caster as the suspension is compressed this is done by having the kick-up of the upper suspenion arm differ from that of the lower arm.... this could possibly be used on pivot ball suspension cars, but I can't see why anyone would want this for off-road as most on-road drivers won't even use it......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-27-2006, 04:48 PM   #1582
yes and no, the chamber actually goes farther negative and the chamber change can actually be adjusted, that is why we have different mounting positions for the chamber rods or upper suspension arms....
Shorter angled down arms provide greater changes, while longer more parallel arms give less change
Longer more parallel arms give less change
The exception---->while (never used) shorter angled up arms provide an increase towards positive chamber...
Unless you ment an increase towards negative.... which is backwards thinking in my mind (but nobody ever said I was always right)
Old 01-27-2006, 06:49 PM   #1583
you're right, i'm thinking backwards. i always forget that negative camber is towards the center of the car. i just say, "increase my camber by .5" to my pitman, and he gets me. sorry for the mixup.
so, from what i understand, when you put the upper front hinge pins to the highest hole, you will experience less ''reactive camber," right? is there any disadvantage of reactive camber anyways? does it affect anything else?
Losi Rock Rey
Old 01-27-2006, 07:07 PM   #1584
the lower position should allow the car to dive into the corner better...unless you already run too much camber..... but when there is enough traction the higher holes should allow the car to go thru the corners faster because the chassis will stay flatter.....
Old 01-28-2006, 12:15 AM   #1585
WheelNut's Avatar
Send a message via MSN to WheelNut
The upper hole should also provide better forward/braking traction on the front end. Although depending on you suspension set up your conering will suffer. Since the chassis rolls in a corner camber gain is required to keep as much of the tires contact patch on the dirt as possible.
WheelNut is offline   Reply With Quote
Old 01-28-2006, 05:27 AM   #1586
krisnata's Avatar
Some one told me the oppossite..... well, best way is to check myself on the track .................
Old 01-29-2006, 12:58 PM   #1587
Default what's new?
Hi Folks!
Since nitro season ended here I haven't really popped in. It's almost time to start wrenching on my cars again and I'm wondering what's new for the Jammin? The only upgrades on my car are the captured hinge pins and one piece motor mount.
What else would you consider an essential upgrade? What about brakes? I'm still running stock.
x-GTer is offline   Reply With Quote
Old 01-29-2006, 01:32 PM   #1588
i suggest that you get the fiber disk brakes. they are much smoother than the stockers, and they last longer too. less fade in those long mains. did you get the aluminum b-blocks too? they are essential.
Losi Rock Rey
Old 01-29-2006, 02:12 PM   #1589
where do I get the fiber disks? I don't have the aluminum B blocks yet, I'll pick those up - thanks!
Old 01-29-2006, 02:24 PM   #1590
nitrohouse has the whole brake kit, i think. check this link. i think it's called "brake special."
http://www.nitrohouse.com/options,_x1.htm
Losi Rock Rey
Jammin/Hongnor X1 - so close yet so far jono mad racer Nitro Off-Road 5 05-08-2011 06:40 AM
anybody close ????? slowpokeRRR Minnesota and North/South Dakota Racing 0 08-24-2007 10:21 PM
close please pwnzor R/C Items: For Sale/Trade 0 06-29-2007 12:40 PM
close Big B R/C Items: For Sale/Trade 0 02-02-2007 10:29 PM
please close racenut123 R/C Items: For Sale/Trade 1 04-30-2003 05:08 PM
