Old 06-20-2011, 05:26 PM   #1
Default Building Mah Kit
The instructions in my kit says to use grease on things like o-rings and bearings, and silicon oil on the gasket on the bottom of the bulk heads. But the kit DIDN'T COME WITH ANY?? Can I just use after run oil or a little bit of shock oil (It says silicon shock oil on the bottle), or do I have to go buy silicon oil and grease?
Bo0m UR DEAD is offline   Reply With Quote
Old 06-20-2011, 05:31 PM   #2
Suspended
Trader Rating: 1 (67%+)
id go and grease beacuse grease is gonna stay on the cvds ect
Hot Bodies Racing, Proline Racing, Byron Fuels, and Radio Post
-Hot Bodies D8 Hara Edition, and D8 Truggy
-B5 and b4.2
rcgarrettp9 is offline   Reply With Quote
Old 06-20-2011, 05:47 PM   #3
go to the auto parts store and get you these 2 things
Fast drying graphite spray.
mobil one sythetic grease.
You do not want to put grease on cvd's, it attracts dirt. I spray my hinge pins, cvd's, pillow balls, joint cups, axles, drive shafts, servo saver post. I use mobil one on ring gears, orings, building my diffs, not much else really.
The 2 things i mentioned are cheap and work very well. You can even get the graphite powder (for key locks etc) and ground the ball ends of your drive shafts.
Another good thing to use is oddonnell lube, it's a wax lubricant that is dry in which case i would put the o'lube on the actual cvd and spray the inside of the joint with graphite spray along with the axle or universal joint cup.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 06-20-2011, 09:16 PM   #4
AZRC4Me's Avatar
An alternative to the graphite is some stuff called Greased Lightning. You can find it at bike stores, and it's used to lubricate bike chains. Works awesome, dries, and doesn't attract dirt. +1 to not using grease in the cvds, only use grease on the diff outdrive cups in the little grease groove that gets inserted into the diff cup, and between the diff ring gear and pinion. Mobile 1 synthetic grease is awesome, a tub of it will last forever and is about $10 or less.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 06-20-2011, 09:24 PM   #5
sound's good. I need to get some. Always looking for better and different fluid/chemicals for my car. I just started wiping down with pledge after i completley clean everything. WOrks good.
Mugen
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Building Serpent 835 tips and questions... mxs Nitro On-Road 67 06-30-2008 10:53 PM
