Rebuilding a DuraTrax Nitro Evader ST....
I've got a nitro evader ST that's been in pieces for a few years, so it's in good shape, everything should be there, so let me know if you need anything.
These are the pics of it on ebay!
Top view
Bottom view
Box with almost everything!
Box arrived 1 July 2011
Open the box to find out what ill be working with...
Top view of it loosely put together, just tryin to get an idea of where everything went, not bad for my first time putting together a nitro with no instructions.
Motor siting unbolted in...
Side view
I was trying to find out what this was but I eventually figured it out
Self explanatory
Top view of it put together and bolted down
Picture of the piece of crap servo - SMARTECH
RIMS beat to crap also tires are on the wrong rims. Doesn't matter imma probably get new rims and tires once i get this thing running
Back side of rim
It should look mean when I get a body for it
So I tried to get power just to see if the servos worked and I got nothing, so I investigated and discovered this....
So I fixed the problem with my awesome wire skills and now I have power, but the servos that came with it are completely trashed..
The battery wire going into the receiver was poorly fixed that will be next to fix...
I also broke this part so im going to have to temp fix it until I can locate parts
I've got a long list of parts that im going to try to locate and i also need to find 2 servos.... until then stay tuned
Top view
Bottom view
Side view
Self explanatory
Back side of rim
i do need a few things, pull starter, 2mm eclip, air fliter set, the socket Head Cap Screw 3x8mm that bolt down the motor, rims and tires, Throttle Return Spring, Brake & Linkage Set Throttle, 2 servos and any Flat Head Machine Screws 3x8mm. Let me know what you have?
Hate to tell you. Once it's together and running you will always be rebuilding it. The tansmition gears strip constantly on it. but a all metal tranny in the drive shafts snap. I would suggest selling it and getting a associated or losi truck and you will have much better luck. Cut your losses befor you loose to much.
R/C Tech Elite Member
Nice project
Why the ribbed tires are installed at the rear?
I do have the X thing that goes on the servo
I have 2 Duratrax I think SX100 servos that have to go to it...
I have the air filter
I should have linkages
I'll rummage through the bolt bins and see if I can find the others.
I also have the Original wheels (Maybe original tires too) and original body in great shape apart from extra holes.
I'll gather it and PM pictures.
I know I only have the handle and 2 pullstarter housings for it.
