Old 06-18-2011, 01:04 AM   #1
Thumbs down slow down
my nitro sidewinder wind hobby buggy has decreased off road dramatically even at half throttle the buggy slows down and evntaully turns off if held but if it starts to slow down and I brake to a stop it then works for a short amount of time this only seems to happen on grass I am not sure but I have not used after run oil befor would this make a difference PLEASE HELP!
Bentvanderkroft
Brentvan is offline   Reply With Quote
Old 06-18-2011, 01:38 AM   #2
Could be a half dozen different things. Have you been playing with the needles? Do you regulary clean\change your air filter? Might have got some dirt in your engine? Pull your clutch apart and check it first.
ratjayfala is offline   Reply With Quote
Old 06-18-2011, 04:49 AM   #3
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
While on grass your wheels are not always touching the ground so it will slow down. Also the motor may be over-reving and over heating as a result. When I first started with nitro I did that to my T-maxx all the time.
awdcameolsx is offline   Reply With Quote
Old 06-18-2011, 07:47 AM   #4
How do I stop my car from over heating
Bentvanderkroft
Old 06-18-2011, 07:57 AM   #5
First, read this thread and learn about proper nitro engine tuning: "the engine tuning bible"
Next, check the clutch and clutch bearings. Clutches are a wear item and have to be rebuilt. Clutch bell bearings go bad often and need replaced regularly.
Continuous running of an engine that's not tuned properly leads to worn out engines. Yours may be worn out and needs replaced.
Also, running a buggy in grass is very hard on the engine, the grass is a lot of drag on the car, making the engine work very hard. Run on shorter grass or dirt/gravel.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 06-18-2011, 04:57 PM   #6
Angry
I know the clutch is not the Problem because the clutch was replaced not long ago I think there may be some dirt in its engine because the air filter fell off and some dirt got in but we th got most of it by tipping it upside down and and washing it out with fuel bat maybe we didn't get all of it how can I remove the rest of it and I don't think its warn out because it only a year old and I don't do any racing or anything I just like to go driving for fun but this problem is annoying
Bentvanderkroft
Old 06-18-2011, 05:19 PM   #7
nitroexpress's Avatar
One good gulp of dirt is enough to send an engine to the boneyard. Take the engine apart and clean. Maybe you were lucky.
nitroexpress is offline   Reply With Quote
Old 06-18-2011, 05:33 PM   #8
Trugsta's Avatar
Send a message via MSN to Trugsta
Deffenetly Pull your engine down and clean it out with nitro fuel.
when your engine is apart take time to inspect all the internal parts including the bearings..
Having said that Im of the opinion that your compression is on its way out wich is quite an easy fix with a new piston and liner...
I am Only taking an educated Guess..
Proud Member of S.C.O.R.C.
Losi 8T2- Novarossi P5/Novarossi and GRP pipes.
spektrum DX3S. SAVOX servos. "Race till it MHZ"
A huge thanks to.
www.motorsaver.com (the absolute best filters and savers on the plannet).
Trugsta is offline   Reply With Quote
what makes my car slow down? vuanhquoc Nitro On-Road 12 05-04-2009 07:27 AM
DONT SLOW DOWN is deffinately a bad dude to deal with BEWARE!! jldjlaudio Buyer/Seller dispute and Feedback discussion forum 131 01-19-2009 03:34 PM
Why should we be made to slow down?! Racingbod85 Electric On-Road 193 05-16-2006 12:41 PM
Site Slow Down tekrsq R/C Tech Site Forum 23 05-14-2003 08:06 PM
