How do you notice diff wear?
If you see the wear marks on the outside of the teeth of the ring gear you are getting close. At that point make it good and tight for the next race and order a new one. Also a good idea is to order a new diff housing at this point because the old one may have worn out at that point. They do get a ton of stresses put on them from many different ways. You can see the wear marks via the shiny part of the teeth. Always check to make sure the wear marks are on the center of the teeth, otherwise adjust your shimming. All the way in is too tight, all the way out is too loose. As a rule of thumb truggy needs to be a little tighter. Hope I helped out there.
get a mugen. I swear these gears don't wear. One of my gearsets is almost 3 years old and just as good as a new set i bought not to long ago, and i still use both sets and i cant see/feel any difference between them. Even the pinions are in great condition.
shim them well, and treat them good and they will last.
Open them up and check.... Thats what I do.
R/C Tech Elite Member
exactly^^^
open them up, clean all your pieces from the diff, clean your case completely.......inspect/replace spider gears...inspect/replace sun gears.....inspect/replace cross pins.....inspect/replace/re-lube bearings in drivetrain while you are there....also check your outdrives/universals.
