Old 06-11-2011, 04:43 PM   #1
Default holes in premounts?
I buy aka premounts and there is no hole anywhere. How do i put these holes in these? Arent they supose to have hole in them? In the rin or something? Can i like burn hole in tire with a soldering iron? i try to cut hole but i can't seem to do it.
Nytrocrzy is offline   Reply With Quote
Old 06-11-2011, 05:15 PM   #2
DPowers's Avatar
Trader Rating: 79 (100%+)
You wont the atleast 2 holes in center of the tires to let dirt out and water just take a pair of scissors and and just cut 2 small holes in the tire one on oneside and one on the other just try to make them about evenly as you can and you should be good to go we use a leather hole puncher if you have one of those they work really good.
DPowers is offline   Reply With Quote
Old 06-11-2011, 05:17 PM   #3
i am having problems cutting holes you can use a leather puch with the tires already mounted?
Old 06-11-2011, 05:40 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
AKA premounts should have holes punched in the tire out of the package. All of mine have anyway.
If they don't, you can still use a leather punch, you will just have to sort of "pinch" the tire and punch it.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-11-2011, 05:42 PM   #5
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
To make a hole with a leather punch, pinch the tires and cut out a half circle on the edge you made with the pinch. After you are done you end up with a whole circle
awdcameolsx is offline   Reply With Quote
Old 06-11-2011, 05:53 PM   #6
Body reamer works fine
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 06-11-2011, 06:11 PM   #7
ScottyM's Avatar
Trader Rating: 27 (100%+)
Or a 1/4" drill bit..
All of my AKA premounts have come with holes already punched also.. They can be easy to over look..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 06-11-2011, 06:24 PM   #8
just put 2 holes in one tire and then realized it already had hole in it.
Does these holes spread and tear the tire by anychance? Seems like the ones i made will just spread, tear and get bigger.
Old 06-11-2011, 09:21 PM   #9
ScottyM's Avatar
The rubber of RC tires is very elastic, I doubt it will get bigger. Besides, it is too late now, so you might as well run them..
Scott Musgrave
Old 06-12-2011, 03:07 AM   #10
I once forgot to put holes before mounting so I used a side-cutter and made some ugly as$ looking holes and they did not rip or become larger.
Life's like a lemon and I want my money back!
Klimpen717 is offline   Reply With Quote
Old 06-12-2011, 06:22 AM   #11
Use a body reamer or the tip of a hot soldering iron to make a neater hole.
Back to AKA's premounts, they probably have one hole only and not easy to notice it if you don't look hard enough...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Poking holes in tires JSR Nitro Off-Road 70 03-11-2015 04:33 PM
What do you want to see in 1:10 buggy and truck from Pro-Line? Up&comer Electric Off-Road 491 10-19-2014 06:38 PM
Punching holes in Short Course and 1/10 Buggy/Tuck tires like 1/8 scale? RC-ZOMBIE Electric Off-Road 7 12-15-2010 04:14 PM
Sand in tires casevac Nitro Off-Road 11 07-07-2009 11:18 PM
