Old 06-08-2011, 04:38 PM   #1
Questions?? HB D8 universal joint
Hi guys, My front universal joint keeps coming apart and ive now lost 2 pins. Ive used 2 different types of thread lock. Does any one have any better ideas for me it s driving me nuts, Cheers.
Rupert 82 is offline   Reply With Quote
Old 06-08-2011, 05:04 PM   #2
ecpete's Avatar
Trader Rating: 39 (100%+)
Teknorc.com has some nice CV Couplers. I have some on my D8T and have 0 issues now.
Team Mugen Seiki - www.Mugenracing.com
Mugen Seiki MBX7R
Pierre Kiti
ecpete is offline   Reply With Quote
Old 06-08-2011, 05:23 PM   #3
kai888's Avatar
Trader Rating: 17 (100%+)
the pin has a flat spot , you have to make sure the grub screw is screwed into the flat spot.
kai888 is offline   Reply With Quote
Old 06-08-2011, 05:24 PM   #4
jammin32j's Avatar
I use a piece of heat shrink over them. I have never had any issues with pins falling out with this method.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 06-08-2011, 07:45 PM   #5
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Use MBX6 center shafts. They fit nice and last way longer. Use a .5mm shim on the cup where it sits on the pinion gear if you want it to sit further in the diff cups but should be fine without.
awdcameolsx is offline   Reply With Quote
Old 06-08-2011, 08:21 PM   #6
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
I've worked on people's driveshafts before that experience this problem. Often they just don't tighten the set screw nearly tight enough. Also the assembly order used can be incorrect which can cause grease interfering with the loc-tite.
I put thread lock on set screw, thread set screw into the barrel until it bottoms out against the pin. Only the pin, set screw, and barrel parts are in hand currently. Remove set screw, thread lock again, thread into barrell until bottoms out, back off set screw just enough so pin can slide out. Wipe off excess thread lock. assembly driveshaft completely, set screw is tight. Apply grease into both sides (both slots) of the driveshaft, insert driveshaft joint boot (I use GMK Supply), insert driveshaft into suspension component.
If you thread lock when everything is together, the excess thread lock can get into the driveshaft joint binding it up. Sometimes the pre-built driveshafts are like this. If you insert the set screw after the driveshaft is built and greased, the grease can interfere with the thread lock.
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
Old 06-08-2011, 10:13 PM   #7
awesome!!! thanks everyone for your help
HB D8 Harra Edition! Simple GREEN R/C Items: For Sale/Trade 11 04-10-2011 08:59 AM
1/8 HB D8 with tekno v3 conversion. bundyracer Electric Off-Road 26 04-04-2011 01:57 AM
NIB PARTS FOR HB D8 1/8 OFF ROAD pinoy69racer R/C Items: For Sale/Trade 12 01-05-2011 06:39 AM
Lelong Selling..HB D8(spare p) / HN Big bore Shock / 1/18 mini truck james wong Malaysian Forsale-Trade 8 10-24-2009 05:23 AM
