Old 06-09-2011, 06:22 PM   #16
ramjesr's Avatar
yes that is the same problem I have, they skip threads and throw off the settings. Does RPM make rod ends for the 2.0 b?
ramjesr is offline   Reply With Quote
Old 06-09-2011, 09:41 PM   #17
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
This may be a little tedious for some but this is what I did after experience rod end issues a couple times. I set everything up with the camber I want, did some marking and measuring. then took an old 4mm hinge pin and cut slugs to the correct length, slide the slug in the rod end, then thread in the rod. That way the rod cant skip any threads. Never had any problems since. it was time consuming but after driving almost an entire 45 min main with one front wheel with "27" degrees neg camber, it was worth the effort!
Tekno RC
Pro-Line Racing Tires, Futaba,
O.S., Hobbico, 92Zero Designs
Danny B R/C Products,
LRT Raceway, Evansdale, IA
Danny B is offline   Reply With Quote
Old 06-09-2011, 10:12 PM   #18
ramjesr's Avatar
so your problem was the rod shortening, my problem is the rods are getting longer.
Old 06-09-2011, 10:18 PM   #19
losi_racer's Avatar
Trader Rating: 25 (100%+)
ive had two different rollers with the lundsford links. i didnt have as extreme of issues as some of you describe but my camber would change a couple degrees. I went to the lundsford link and my camber is always spot on now.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-09-2011, 10:33 PM   #20
ohh EPiC FAiL's Avatar
Trader Rating: 51 (100%+)
yeah i figured out which 3 links i've stripped, so now i'm just gonna go ahead and replace the ends on the other 3 and see what happens. i may try what was mentioned above, cuz i tend to end up with a TON of negative camber when they strip. if i replace the rest of them and keep stripping them i will most likely just get the lunsford links.
TEAM FEARLESS RACING
I Race: Losi 8ight-E 2.0
I Crawl: XR10(almost VP10)
I Support: Futaba--Holmes Hobbies--Savox--Castle Creations--Tekin
ohh EPiC FAiL is offline   Reply With Quote
Old 06-10-2011, 06:52 AM   #21
Danny B's Avatar
Hmm, never had it happen the other way but I could see it, if you tumble just right. My fix won't help that...
I just didn't want to spend the money on all new stuff when I felt I could solve the issue with a little sweat and a couple cut-off wheels.
Tekno RC
Old 06-10-2011, 07:14 AM   #22
ramjesr's Avatar
yes thats when it happens after a good tumble.
Old 06-10-2011, 09:22 AM   #23
ghost68's Avatar
The problem with suddenly getting a lot of negative camber is because up until mid last summer all of Losi's turnbuckles were pressed together instead of being threaded into place. This weakens the plastic and makes them strip very easily... The fix is cheap and very simple: Replace all of the rod ends and thread them on by hand.
I have ~ 11 Gallons on my 8ight-t 2.0 I had three turnbuckles go within the first four gallons. I replaced all of the rod ends in one go and haven't had a problem since...
-Dustin Bullard
***HoBao Hyper Star/JL .21PRO/2047/Savox/AKA***
I would like to say Thanks to my sponsors: Team OFNA and Sidewinder Fuel
ghost68 is offline   Reply With Quote
Old 06-11-2011, 07:49 AM   #24
Trader Rating: 30 (100%+)
Get the 1.0 stuff. Alot of gallons on the chassis and haven't touched them.
Axial Wraith
sdtech58 is offline   Reply With Quote
Old 06-11-2011, 09:45 AM   #25
wmwracing's Avatar
Don't screw around. Get the Lunsford ti turnbuckles. The only way you will bend one on a 1/8 scale losi is if you drive wide open into a brick wall. Then he will give you a new one for free.
Losi 8ight T 2.0 O.S. Speed
Losi 8ight 2.0 Novarossi Plus4C
Assocaited 4.1Worlds Novak
Losi XXXT CR Novak
Lunsford Racing
wmwracing is offline   Reply With Quote
Old 06-11-2011, 06:35 PM   #26
Trader Rating: 20 (100%+)
X100
Matt Piva is offline   Reply With Quote
Old 06-11-2011, 09:36 PM   #27
Integra's Avatar
Imo the 5mm's are overkill In weight and durability. 4mm's are More then enough and if you don't want to be replacing the balls due to being aluminum and wearing, Source some steel balls.
Old 06-12-2011, 12:00 AM   #28
ferrarieeeee's Avatar
I'm using this and put a washer under the cup head screw, the turnbuckle never pops out
http://www.amainhobbies.com/product_...Flanged-Ball-2
Electric: eb48.3 / eb48sl / 811e / d413 / b5 / b5m / kr / pro2b / msc / scte
Nitro: nb48.3 / xb8
ferrarieeeee is offline   Reply With Quote
