Old 06-03-2011, 03:02 PM   #1
Littlejohn Dsgn's Avatar
Trader Rating: 47 (98%+)
Default Chewing up my Start box wheel
Ok so I am feeling like a total Noob asking this, but I have next had this issue before and I just cant seam to figure it out.
I have a new (well new to me, but I dont think the last guy drove it much) Losi 8ight-T 1.0 with the Losi 454 engine. I also bought a new Dynamite starter box (1/8th scale version with two big motors). The box starts up my brothers 8b just fine (aftermarket engine). When I put my truggy on the box I just smoke the starter wheel to the point that I have put a groove in it. I have used my heat gun to warm up the engine before trying to start but it still will not turn over.
Any ideas of suggestions of what to check?
Scott Littlejohn - Owner of Littlejohn Design
Fleet - FT B4.1(FS) - FT T4.1(FS) - Emaxx - Micro T's (4)
Littlejohn Dsgn is offline   Reply With Quote
Old 06-03-2011, 03:24 PM   #2
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Make sure ur box i lined up proper to the engine. Easiest way to see is take engine out and line box up with flywheel slot on chassis. Once you have done that reinstall engine and see if it still does that. If it dont your good to go if it does and using a heat gun still locks engine at top loosen your plug just a bit to release some compression. If the engine has been ran a bit it should start easily, if the plug has to be loosen then its not broken in and engine is pretty new.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 06-03-2011, 03:26 PM   #3
Thanks I had the engine out when setting up the box so its all lined up, will try to loosen the plug a bit and see if that helps ... (fingers crossed, a newer motor then I thought is a good thing )
Old 06-03-2011, 03:29 PM   #4
If this is the problem i strongly incourage you to break it in. If you dont engine wont last near as long and engine wont run right. There are many break in stlyes to use and many ways to find them. Google works or check out the break in bible here at the engine thread which is on the top in the nitro off road thread.
Old 06-03-2011, 03:36 PM   #5
Thanks I loosened up the plug and it started right up, I will go check out the break in bible. Turns out the deal was better then I thought, a newer motor to Now to break in a motor......thanks for your help.
I was starting to remember why I got out of nitro and into electric, lol but as soon as the motor fired up I remembered why I wanted back into Nitro
Old 06-03-2011, 03:48 PM   #6
Yup i went e for a while but the noise brought me back and now that i got all dialed in my e car sits in pieces lol. Its a good thing if your engine needs to be loosend on plug to start, thats means its basically new.
Old 06-03-2011, 05:11 PM   #7
Suspended
Trader Rating: 202 (96%+)
not only loosin up the plug, but might want to preheat engine before starting again, those 454's have come tight from the factory, preheating will let you engine live a long happy life....loosin the plug to much and.....well ive seen a few blow right out of the head button, was pretty cool, but not for the owner of the car.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 06-03-2011, 07:37 PM   #8
Also, make sure your motor is at BDC before you start it up.
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 06-03-2011, 09:24 PM   #9
Thanks everyone, I had to loosen the plug (just a bit) then tighten it back down after it was started. I was preheating the engine also but with the plug tight it was not enough. I also always put my engine at BDC when I am done running and check before starting.
