Old 06-01-2011, 07:18 PM   #1
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
Default FELLOW MUGENITES....LET ME PICK YOUR BRAINS FOR A MOMENT...
I'm racing a MBX5t (BCE chassis, big bores, MBX6t gearing, ect...) while walking by my work bench this evening, i ran my hand over one of the wheels and only 3 turned......checked the one that wasn't and the barrel inside the CVD was snapped. (hasn't happend to me EVER with ANY scale R/C, but there's a first time for everything...) no big deal, i pull the front CVD out and try to replace the broken barrel with a new one BUT (there's always gotta be a but...) the whole CVD (up to the outer axle that the hub mounts to) is SMALLER in diameter than the rear and takes a smaller barrel... was this typical?? everywhere i look for parts it shows both F/R are interchangable but for which size, the standard (bigger) size or these tiny wussy ones that are on the front of my truggy?? (the rears are the same size as a standard MBX5r a.k.a. BIGGER)
anyone have a clue on were i can find these "little barrels" at??
or if the CVD bones from the caster K8t are the "BIGGER" ones so as i can replace these tiny things with something sutable for a truggy??
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 06-02-2011, 12:05 AM   #2
Hey dude barrels all the same ! shafts can get slop in them may make them look to small ! ?
moonie1 is offline   Reply With Quote
Old 06-02-2011, 12:43 AM   #3
curacing2's Avatar
just to clarify whats what, are the cvds, mugen 5T or something else?
what brand cvd barrel were you replacing it with.
as Moonie said, all mugen barrels have been the same from the mbx4 up to the mbx6 and 6T, I wonder were your old mbx4 is these days?
i have had a barrel brake and i broke one doing it up too tight but they were on the centre drive shaft cvds...nice thing with the 6 hubs and drive shafts is the pin is captured buy the inner bearing...thats what i'm running on my 5T.
curacing2 is offline   Reply With Quote
Old 06-02-2011, 02:51 AM   #4
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Throw a set of calipers on it or a micrometer,then look it up. (or use the owners manual available via PDF) When I was driving mugen I had this happen to me. I started replacing them every 2 gallons on a truggy. They hold up to buggy but not on truggy IMO. Yes they do break and you lose just about all your power. Replace the plastic diff housing while you are at it. Chances are its prolly warped by now as well.
awdcameolsx is offline   Reply With Quote
Old 06-02-2011, 01:51 PM   #5
hustler777's Avatar
ok, factory mugen barrel is .232in
broken barrel is .196in
im thinking that the previous owner used some cheap knock-off brand CVDs...gonna do s'more searching to find out where from...
anyone know the exact length of these long monsters?
Old 06-02-2011, 02:00 PM   #6
motomatt's Avatar
gimme til tomorrow and I'll tear one off Kath's and measure?
motomatt is offline   Reply With Quote
Old 06-03-2011, 05:10 PM   #7
motomatt's Avatar
6T drive axle is the top one. Barrels are the same. 6T shaft is about 4 mm longer, both are the same diameter. The pin for the 6T barrel is about 0.5mm shorter. "Ball" diameter at the CVD is the same.
The 6T axle bearings are spaced further apart in the carrier, the 5T bearings are almost side by side. And, of course, the 6T axle bearing captures the barrel pin.
Old 06-03-2011, 05:13 PM   #8
motomatt's Avatar
Oh, just to clarify.....................I'm a Mugenista, not a Mugenite.
Old 06-03-2011, 06:25 PM   #9
hustler777's Avatar
thanks alot guys....i think i got things figured out now.....i'm gonna drill the lil bones out and throw them on the back for a weekend....i figure by then i should have the RIGHT replacement parts....plus they'll most likely be wore out and/or twisted after one night of racing....
oh, and moto...i knew there was something different about you....
Old 06-06-2011, 04:00 PM   #10
hustler777's Avatar
well i was wrong saying the little cvd's were cheap knock off's....they're off of a hot bodies d8t.....
Old 06-06-2011, 04:04 PM   #11
Jaz240's Avatar
Trader Rating: 52 (100%+)
I love your threads Wayne..they are always entertaining
nothing to see here................................
Jaz240 is offline   Reply With Quote
