Old 06-01-2011, 07:58 AM   #1
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
Default need help on motor
Ok I have a d8 buggy.....I thought all big blocks mounts the same..well there not.. ok I have a ae 21 r pro motor ...the stock motor mounts wont fit... so how to I mount it?
catch me if you can....
WWW.RCFANATICS.NET
http://rcraracing.com/sitebuilder/images/FORUM/index.php
C&D R/C RACEWAY
Team Wicked Racing
MADMAN23 is offline   Reply With Quote
Old 06-01-2011, 02:15 PM   #2
j_blaze14's Avatar
Trader Rating: 34 (100%+)
its a 3 part motor mount, the 2 top plates the motor bolts too come off for clutch work so you don't have to reset the mesh every time. once the mesh is set from the bottom those screws are untouched, unless you change gearing. best thing to do is take motor mount out from bottom of chassis, loosen the 4 screws that hold the brackets to the top of the mount then bolt up the motor. tighten the 4 screws on the brackets then install mount/motor and set mesh.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 06-01-2011, 04:47 PM   #3
MADMAN23's Avatar
It wont for that motor mount ...
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 06-01-2011, 04:50 PM   #4
Suspended
Trader Rating: 202 (96%+)
, it wont what?
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 06-01-2011, 04:51 PM   #5
MADMAN23's Avatar
Here the motor I have..http://www3.towerhobbies.com/cgi-bin...?&I=LXFUU2&P=7
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 06-01-2011, 04:52 PM   #6
MADMAN23's Avatar
Originally Posted by inferno13 View Post
, it wont what?
The base is different.
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 06-01-2011, 04:54 PM   #7
Suspended
ahhhhh.......you have a pull start? wont fit with that motor mount, may need to convert to bump start
Old 06-01-2011, 04:59 PM   #8
MADMAN23's Avatar
That's fine.. how do I get it to fit?
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 06-01-2011, 05:03 PM   #9
Suspended
whats fine?? think you need to give more info.
Old 06-01-2011, 05:16 PM   #10
MADMAN23's Avatar
Bump start if fine..
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 06-01-2011, 05:19 PM   #11
Suspended
so you have a bump start, roto start, bump start........ERRR i give up
Old 06-01-2011, 05:42 PM   #12
the engine won't fit. you need a big block engine that has standard big block mounts.
one8updragracer is offline   Reply With Quote
Old 06-01-2011, 06:46 PM   #13
madac's Avatar
The pullstart plate on the back of the engine is the problem but you need to take the whole pullstart assembly off of the engine until you can see the conrod, piston assembly and the sleeve and then you need to buy a flush back plate and a piston and a crankshaft that will work with the bump start back plate assembly.
The D8 was not designed to work with a pullstart and from what I know you can't buy an engine mount to work with one unless you get it specially made for it.
Instead of trying to convert the engine you have and trying to find parts that may or may not work take a look in the for sale section there are alot of great sellers on here that are selling bump start engines that would probably run better than the Associated engine you have. I run Reedy 121vr's in my D8 and D8T great engines and they cost around about $230 at a-main.
Is the engine you have new or used? If it's new try and return it and get a bump start engine, a good bump box and a battery for the bump box.
If not look in the for sale section for a used bump start engine, starter box and a battery for it.
Team Associated B5
Spektrum DX3S
madac is offline   Reply With Quote
Old 06-01-2011, 07:14 PM   #14
MADMAN23's Avatar
It is new
. I bought it off from a member on here tho...it never seen fuel...
WWW.RCFANATICS.NET
C&D R/C RACEWAY
Team Wicked Racing
Old 06-02-2011, 01:03 AM   #15
curacing2's Avatar
Madac is right, as the link said its for a replacement motor for a monster truck.
What was in the D8 or did you buy a 2nd hand roller.
sell it on and buy a .21 race motor, when its hauling ass after run in you'll know were we're comming from.
How many years have you lot been on rc tech?
5000+ posts OMG
curacing2 is offline   Reply With Quote
Need opinions on motor and esc for Slash 4x4 LEWETHETIGER73 Radio and Electronics 8 03-11-2010 07:46 AM
Need help on Tamiya ESC ket2175 Singapore R/C Racers 8 07-28-2009 12:40 AM
Need help on motor turn..I confused azmin Electric Off-Road 11 02-17-2009 09:49 PM
Need help on a Brushless System tom_chang79 Electric Off-Road 22 07-16-2008 11:11 AM
