Old 05-30-2011, 03:12 PM   #1
emancipation007's Avatar
Default Wheel balancer
Does the wheel balancer work well
On road and offroad man I love racing
emancipation007 is offline   Reply With Quote
Old 05-30-2011, 06:18 PM   #2
pickle311's Avatar
Trader Rating: 31 (100%+)
A wheel balancer is a must have tool. Makes all the difference in the world.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 05-31-2011, 11:44 AM   #3
rangerjkb's Avatar
Trader Rating: 38 (100%+)
Send a message via MSN to rangerjkb
Absolutely, you'll feel the difference imeadiately.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 05-31-2011, 11:52 AM   #4
you will see a huge difference in how your ride handles.
Hot Bodies D8t- Clockwork JL 21/ AB mods C6, JP-1, Spektrum DX3R, JR servos, AKA tires
Hot Bodies D8- RB WS7 III, GRP 2053 pipe, Spektrum DX3R, JR servos, AKA tires
Losi 8t 1.0 mostly upgraded to 2.0 via ebay- RB C5, dynomite 086, spektrum DX3S, orion servos, AKA tires
Muggified LST- Teal head 427, RD logic pipe, JR servos, panther tires
morkendi is offline   Reply With Quote
Old 05-31-2011, 12:07 PM   #5
DiZzYNaTiOn's Avatar
Trader Rating: 25 (100%+)
+1 i cant believe i raced without one, just get some molding clay (the one with oil in it) not the one that dries out.
I have not vibrated any screws out of my car since i got one. And its just so much smoother
www.filmmakerforum.org
RC8B3 - OS Speed .19 - S9352HV - 4PKS
DiZzYNaTiOn is offline   Reply With Quote
Old 05-31-2011, 12:45 PM   #6
JsK
JsK's Avatar
Great tool and you will notice a difference,but there is a learning curve
on how to use one correctly.
This is the one you want
http://www.amainhobbies.com/product_...Wheel-Balancer
The one with bearings have to much drag. You will also need a spare
hub to use on the shaft. And some Lead Tape Weight. You can get the
lead tape at any Golf Pro shop.
JsK is online now   Reply With Quote
Old 05-31-2011, 01:12 PM   #7
Thats because of the rubber seal and the grease inside, just remove the rubber seal and get rid of the grease with your choice of spray lube, then the drag that came in the stock bearings are gone and then its time to do some precise balancing
Old 05-31-2011, 01:50 PM   #8
Fd2k's Avatar
Im thinking of getting the losi brand myself and it has the bearing... So you mean that one has drag also?
Losi 8ight 3.0 / Novarossi P5 / Novarossi Pipe / Hitec servo / GunHill Track ( Ft Knox Park ) / Spektrum / Werks Fuel / Proline /
Fd2k is offline   Reply With Quote
Old 05-31-2011, 01:56 PM   #9
pickle311's Avatar
Bearings by design will have a little more drag at first. As stated, get the grease out and run it dry then the drag will be gone.
I personally use the Dynamite balancer and I replaced the bearings in it with ceramics. I also blew the grease out of them, it will spin for days.
Old 05-31-2011, 03:50 PM   #10
Dynamite balancer here too.
Replaced bearings with metal shielded bearings, no grease and it will spin forever and ever......
McFly505 is offline   Reply With Quote
Old 05-31-2011, 04:04 PM   #11
Are they a necessity on a truggy or mainly buggy ?
moonie1 is offline   Reply With Quote
Old 05-31-2011, 04:24 PM   #12
i would say anything that has wheels and races. Bashing, not so much.
Old 05-31-2011, 07:29 PM   #13
pickle311's Avatar
more of a necessity on truggy than buggy due to the larger wheels, but equally important on both
Old 05-31-2011, 08:57 PM   #14
vwduud's Avatar
Trader Rating: 45 (100%+)
My wheel balancer consists of a Losi Eight 2.0 rear hub, axle, bearings and the 17mm hex wheel adapter. Built from worn parts. Cheap. Works as good as the Dynamite balancer I had - if not slightly better.
Holding the hub by hand and gently shaking it (with a wheel installed), helps to allow the heavy part of the wheel to settle.
And as someone mentioned above - use adhesive backed lead swing weight found at golf pro shops.
Jim Brown
Tekno EB-48.4, ET-48, Rx8 G2, 1900kv/2000kv, Savox 2274/2273, SMC, 4PX
Sponsors: Tekno, RC Crew Chief (chassis tuning S/W)
President of SCR (just outside New Orleans) - https://www.facebook.com/scr.raceway
vwduud is offline   Reply With Quote
Old 06-01-2011, 12:05 AM   #15
JsK
JsK's Avatar
Yes you can fix or modify the bearings in the Losi,Dynamite,or Hudy
units but why? The DuBro unit works perfectly right from the box.
wheel balancer help! lewis666 Nitro Off-Road 45 05-27-2011 04:38 PM
whats a good wheel balancer? bigguyrc8 Nitro Off-Road 20 02-05-2010 08:39 PM
Hudy wheel balancer trap121 Electric Off-Road 15 09-08-2009 09:26 AM
New Wheel Balancer Machine's R/C H Nitro Off-Road 26 03-10-2008 09:20 PM
Niftech Ultra Precision RC Motor Armature and Wheel Balancer #3100 EngTat R/C Items: For Sale/Trade 33 10-30-2007 04:15 PM
