Old 05-30-2011, 10:30 AM   #1
chenzo6508's Avatar
Default when did you start realizing your setup changes worked
when did you start feeling that your changes worked and also what changes do you think are the easiest to feel right away
Owner 5th Gear Designs
chenzo6508 is offline   Reply With Quote
Old 05-30-2011, 10:40 AM   #2
Tires. Then shock and diff oils, pistons, etc.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 05-30-2011, 10:46 AM   #3
dug44's Avatar
Trader Rating: 29 (100%+)
Easiest change i saw work immediately was when our local pro driver told me to add 2mm shims under the turnbuckles of my rb-5. It was pushing through the turns instead of actually turning. Thougt he was full of it..... Until the very next lap. Couldn't believe the change in steering, all over a 2mm shim.
Thats just the start of it.
Dropping the tranny in the rb 1mm was amazingly obvious as well. Forward bite increased insanely.
Before that stuff, i thought mm shims were a waste of time. But hey, what do i know....
Doug Koenig
KYOSHO rb5 sp2/scr/db/mp777e sp2 wc
MIP scte/sc10 4x4
Upgrade rc/ Hilton hotels
dug44 is offline   Reply With Quote
Old 05-30-2011, 10:49 AM   #4
tc5 man's Avatar
man i whould have to say doing the easy things first like camber and toe in/out.
oh and tires for sure !
you dont have to be a pro driver to notice it.
Old 05-30-2011, 10:51 AM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
For me the most productive changes are Camber to the front and rear. when set correctly you can really hung the turns with more speed and of course the right tires. Its a great adjustment when you get it just right, but has to be changed according to track conditions. To much negative camber and you traction roll, to little and the end breaks free, but when I get it just right its completely dialed!
nothing to see here................................
Jaz240 is offline   Reply With Quote
