Old 05-28-2011, 08:59 AM   #1
Jimmy Avila's Avatar
Trader Rating: 81 (100%+)
Default Problem charging lipo glow igniter
I have a dynamite lipo igniter and when I try to charge it my charger says over voltage. It's a Hyperion charger. Any advice?
Jimmy Avila is offline   Reply With Quote
Old 05-28-2011, 04:36 PM   #2
Integra's Avatar
What are your settings on the charger ?
Old 05-29-2011, 03:46 AM   #3
Trader Rating: 25 (100%+)
Are you sure it's a "LiPo" igniter and not a NiMh one?
Kyosho MP9, STRR Evo 2
OS Engines, KO Propo
AKA
Nitro X Fuels
smelly62 is offline   Reply With Quote
Old 05-29-2011, 06:28 AM   #4
pballer2777's Avatar
Trader Rating: 27 (100%+)
Mine did the same thing. I just stuck with the wall charger.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 05-29-2011, 06:36 AM   #5
Suspended
Trader Rating: 202 (96%+)
i just use the wall charger also.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 05-29-2011, 06:46 AM   #6
adrictan's Avatar
The charger that came with the set does not have any power rating. I'm not sure if it's my hse power or if it's a defective unit but the charger poofed when I plugged it in to charge after abt 10secs.
Sponsors: T-Bone Racing, Misfit Design Group, Maclan Racing, IB Prostart, PTRC Oils, Vision Racing Products, SRT Servo, Boca Bearing, Soar Seiki.
Soar Enquiries: adric.tan@soarseiki.com
adrictan is offline   Reply With Quote
Old 05-29-2011, 11:03 AM   #7
I was thinking the charge circuit was built into the igniter and the wall wart only supplied power. If that is the case then you would be trying to charge a charger that was trying to charge the battery.......don't think you can make that work.
bentgear is offline   Reply With Quote
Old 05-29-2011, 11:48 AM   #8
I've used both a cheapo HobbyKing and a Racers Edge charger with the Dynamite LiPO ignitor without issue. I'm using a universal radio chargig adapter. Perhaps the polarity of the plug tip you are using is reversed?
Sponsored by My Kids' Inheritance
Serpent S811 Cobra | Novarossi Plus 21-4T | Airtronics M11x | Savox Servos
mthird is offline   Reply With Quote
Old 05-29-2011, 11:50 AM   #9
true but the instrutions say you can charge it at 1 amp through a normal lipo charger which mine wont do either it starts charging then after aroumd 30 to 50 mili amps says its full and its not
the daddy is offline   Reply With Quote
Old 05-29-2011, 04:04 PM   #10
Have the right adapter end so I will have to give it a try and see what happens. It would be nice to know the mah it takes to charge it back. Thanks guys.
Old 05-29-2011, 07:45 PM   #11
Default charge settings
ime charging at 1200mah lipo
but when i checked the voltage at the glow end it was 4.2v,instructions said it was governed to 1.5v.
still dont glow,just gets warm,?
noddy2 is offline   Reply With Quote
Old 05-29-2011, 08:07 PM   #12
Frank L's Avatar
Trader Rating: 148 (100%+)
Yep. No issues here. I have 2 of them and they both work fine when I use the wall chargers that came with them.
Old 05-29-2011, 08:26 PM   #13
You would need to measure the voltage on the glo plug end when it had the amp draw load of a glo plug placed on it to get a true reading.
Old 05-30-2011, 12:45 AM   #14
uh-oh, i just bought the ignitor without the wall charger hope it can be charged using a lipo charger using the glow adapter.
Will update as soon as it arrives.
jurutera is offline   Reply With Quote
Old 05-30-2011, 01:24 AM   #15
Default 240 v wall charger ?
thanks Frank .how long do they stay charged ? can you get a full days racing out of them ?.
does anyone know if a 240volt charger is available for these units ?Australian compliance.
if not, anyone want to by one,brand new,no charger.
jonando
The best glow plug ignitor?? barrydidntknow Offroad Nitro Engine Forum 119 06-12-2016 11:23 AM
