Which tires, rims for mbx5t?
#16
but maybe im completely wrong
#17
everyone i saw running a MBX5T ran offset... but maybe im missing something or they were just running the wrong wheels.... i just remember alot of people being glade the MBX6T used the wheel extension to use 0 offset and then others not liking it because they had so many offset wheels...
#18
These are the stock wheelhexes for the MBX5T as you can see they are allready extended, if you use these with 1/2 offset rims your truck is to width and you will loose alot off steering :
http://www.amainhobbies.com/product_...-Wheel-Hub-X5T
What some people do on the MBX5T and MBX6T is use 2mm buggy hexes and then use 1/2 off set rims, that will make the truggy narrower and you will gain some more offpower steering but, the truggy will be less stable.
http://www.amainhobbies.com/product_...set-Wheel-Hubs
#19
I just test drove it with the new zero offsets i bought and its great! I drove it hard on grass and pave and never had 1 roll over. Im happy with them!
