Old 05-21-2011, 05:24 AM   #1
Nogas's Avatar
Default Is this the right washer set for shimming mbx6 / 6T diffs
Are these the washers for shimming outside of the bearings (against the diff housing) and the pinion?
http://www3.towerhobbies.com/cgi-bin...3&I=LXVZJ6&P=K
Tekno RC
MBX6e V4 Tekno
MBX6Te V4 Tekno
Nogas is offline   Reply With Quote
Old 05-21-2011, 05:56 AM   #2
robbieg's Avatar
Trader Rating: 26 (100%+)
any 13x16 shim will do. i wouldn't pay that for shims. here's you a link with shims and different thickness so you can dial it in just rite.
http://www.amainhobbies.com/advanced...13x16+&x=8&y=7
robbieg is offline   Reply With Quote
Old 05-21-2011, 03:54 PM   #3
Nogas's Avatar
thanks robbieg, thats a heaps better price. Any idea on the size of the pinion shim?
Tekno RC
MBX6e V4 Tekno
MBX6Te V4 Tekno
Old 05-21-2011, 07:24 PM   #4
robbieg's Avatar
i had a 6t a while back but i think the pinion used 8x16 bearings. if so, you can use a 8x10 shim. i never had to shim the pinion on my 6t though. hope this helps.
Old 05-22-2011, 05:13 PM   #5
Nogas's Avatar
Thanks again robbieg
I have pretty bad front to back movement on the pinions so figure they need shimming, or is this normal? if its normal how much slop should there be. The front diff pinion moves about 1.5 - 2mm and the rear under 1mm.
Or should i be shimming the diff tighter so the ring gear pushes harder against the pinion?
Tekno RC
MBX6e V4 Tekno
MBX6Te V4 Tekno
Old 05-23-2011, 05:25 PM   #6
daveflyr's Avatar
the pinion gear is installed through the 2 8X16 bearings that are installed in the diff case. then the center shaft is installed onto the pinion gear and the
set screw is tightened (with loctite on the threads). there should be little to no for/aft movment of the pinion gear at this point. you would then shim the diff gear so as to have no side to side play, and some gear back lash.
the manual is availible at mugen seiki for download.
HTH, Dave
Mugen MBX6, Novarossi Plus 21-4C, Hitec
Mugen MTX4R, Novarossi Plus 12-3SCT
Serpent S411TE, Serpent S411 Eryx 3.0,
Kyosho Evolva M3 Evo, Novarossi Flash 21PT
Spektrum DX3R, Sanwa MT-4S
daveflyr is offline   Reply With Quote
Old 05-23-2011, 06:39 PM   #7
robbieg's Avatar
when you install the axle and grub screw on the pinion this should be done with the diff case split. you can push the pinion towards the outside of the diff housing while holding the axle as far on the pinion as posible then tighten down the grub screw. this method should take care of any in/out movement. if not then shim it.
