Old 05-20-2011, 04:26 PM   #1
Trader Rating: 17 (100%+)
Default Thinking Of Going Nitro - Losi 2.0 RTR
I have been driving electrics for a while and I am thinking about giving nitro a shot. I am pretty set on the Losi RTR Buggy, sounds like it could just use a few things, clutch, servos after a bit, any thing else?
Can you pretty much drive nitros tank after tank, just keep filling up when it gets low, or will this motor run too hot? That was the bummer with electrics, seemed to need a break after one battery pack to cool off. Id like to be able to run longer with less wait time, and longer mains would be nice. What is the best running temp for nitros? Any other good info for a first nitro would be appreciated.
Trialser is offline   Reply With Quote
Old 05-20-2011, 04:28 PM   #2
Also, what is a good race fuel to use? I found some 20% Byrons for a pretty good price, but not real sure on what % is best for long mains.
Old 05-20-2011, 04:34 PM   #3
JASON671's Avatar
Trader Rating: 50 (98%+)
25% to 30% would be best for racing. if your motor is tuned corectly you can run it for an hour or more tank after tank. byrons, sidewinder, odonnell fuel are the best and most easy to get. i prefer byrons. i use it in my cars and helicopters.
JASON671 is offline   Reply With Quote
Old 05-20-2011, 05:05 PM   #4
abqNitro's Avatar
Yea I usually run mine for 45mins-1hour at a time, which is also around the time my receiver battery is getting low...Ive tried a few fuels but I really like the 30% S&W Trophy blend the best! My engine seems to run cooler and get better lubrication with that brand!
I would much rather be a roach in Heaven than a king on Earth!!
Losi 8T 2.0, ClockWorkRacing O.S. 25XZ, S&W fuel.....
abqNitro is offline   Reply With Quote
Old 05-20-2011, 05:49 PM   #5
Thanks for the input, that is what i was hoping to hear. What size lipo is best as a receiver pack for the losi?
Old 05-20-2011, 05:52 PM   #6
I have the RTR trust me if you already race,just buy the roller.Which is what mine has been converted to after about 400 dollars in upgrade parts ect.The RTR was/is great especially after coming from an electric background.And I also use the S&W 30% It no doubt runs cooler than others and has the power of all the other fuels. Just my 2 cents good luck in whatever you decide to do.
Losi 8B 2.0,Clocked B6&2058 pipe,Answer r/c
AKA,Futaba/spectrum and some other expensive stuff.
The fisherman is offline   Reply With Quote
Old 05-20-2011, 06:29 PM   #7
What makes the race roller so much better? I looked but only saw a few things. Is the rtr engine pretty decent, long lasting?
Old 05-20-2011, 07:01 PM   #8
although im not a losi guy i do have some experanice with 1, the race kit or roller have a better chassis and towers and alum. shock caps. im sure there are other diff. in my opinion the rtr would be fine for getting into nitro but the stock servos are pretty bad so u may want to change them.
rc8 racer is offline   Reply With Quote
Old 05-20-2011, 11:23 PM   #9
I've had the 2.0 RTR for 2 months now and it's definitely the best bang for your buck, but it isn't perfect. My Losi 350 engine has been having a problem 'vapor locking', it doesn't like to start back up after flaming out, if the engine is above 200 deg F it's a real pain to get started again. This didn't happen for the first month but has been a problem over the last 2 weeks or so. I've been told this usually happens when the air temp is ~85 F or above (don't know if this is true or not).
As far as the rest of the kit, its great. People say to replace the shock caps to the aluminum ones but I haven't done that yet, the stock caps have been treating me just fine. The only upgrade i've done is add the DE Racing mud guards. I've ran 3 gallons through it and the only thing i've broken is a shock rod end. Besides the problem with the engine its been a great kit!!!
The only thing I can think of to replace as soon as you can is the servos.
Renfro88 is offline   Reply With Quote
Old 05-21-2011, 08:32 AM   #10
I have a electric 1.0 and it has held up great, towers and chassis seem strong enough. I also have some extra shocks with shock caps i could put on the 2.0.
For the clutch upgrade do I just need the shoes? People say go to a four shoe set up, will these shoes fit in the stock bell?
http://www.amainhobbies.com/product_...Shoes-4-Medium
I don't like the sounds of that vapor lock issue, is that common and can it be fixed with a different carb?
Old 05-21-2011, 01:09 PM   #11
I don't know if the vapor lock issue is common, i've done a google search and found a few people that had the same issue. Some people have said they've tuned it out of their engine, but I haven't been able to do that yet. The guy at my local hobby shop said a different carb with an insulator would fix the problem but Losi's carb is a weird size and the only one that would fit is a Picco. I've been thinking of putting a new pipe on it to possibly bring the temps down, mine runs at about 240, (which is normal for that engine/pipe combo from what i've read) and also upgrading to the turbo head.
The clutch is something I forgot to mention. The RTR only comes with 2 shoes so I did add a pair of composite shoes w/ green springs. I also had to buy the clutch hardware ($5) because either the kit didn't come with extra clutch pins or I misplaced them.
Old 05-21-2011, 08:37 PM   #12
Interesting to hear you say this b/c i've been having a hell of a time getting it back started again as well. it was 89F today and it was really bad re-starting. Also i had a hell of a time keeping a idle. it would tune fine on the box at 170F but then i'd run it up to about 250 on the track and it would die on idling, then cool down back on the box fine and repeat.
Is there a fix for the 350 bugs mentiond?
mtwinste is offline   Reply With Quote
Old 05-21-2011, 08:42 PM   #13
ohh EPiC FAiL's Avatar
Trader Rating: 51 (100%+)
shop around and find a good used roller. i did that and bought all new electronics and engine and i've only spent about $800 out of pocket which isn't a whole lot more than the RTR. you'll be glad if you do the RTR is a good option for the most part, but it does need a few things which will make quite a bit more than it's retail cost alone
TEAM FEARLESS RACING
I Race: Losi 8ight-E 2.0
I Crawl: XR10(almost VP10)
I Support: Futaba--Holmes Hobbies--Savox--Castle Creations--Tekin
ohh EPiC FAiL is offline   Reply With Quote
Old 05-21-2011, 08:59 PM   #14
Doitinthedirt's Avatar
as the rtr parts break just upgrade to the race parts...that's what i did... and also change out servos when they go bad.. buy some new ones send you old servos to losi to get fixed and use them as back ups....
Doitinthedirt is offline   Reply With Quote
Old 05-25-2011, 08:28 PM   #15
I ended up getting a used race roller almost rtr with engine. So, what is the best temp I should try to keep my engine? What is considered too hot to keep running? i have read that you can usually get a little more power out of 30% fuel, is it worth getting that over 20%?
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46468 03-20-2017 08:56 PM
RTR 2.0 Question williamsfw2427 Nitro Off-Road 8 01-02-2011 08:48 PM
8ight-t 2.0 rtr??? 1cougar1 Nitro Off-Road 28 06-04-2009 09:00 PM
<< Losi 8T 2.0 RTR >>Are they going to do it??? Outtacontrol58 Nitro Off-Road 23 04-14-2009 07:38 AM
