Old 05-20-2011, 07:17 AM   #16
gabor szilagyi's Avatar
Originally Posted by Burney View Post
erm i dont know whether your joking or not
Call me crazy or what ever but I did not joke!Some of my friends did this so I gave a try yesterday and it's working .But you need to know what you doing.If u have a used tank u can try it too.1)pre heat the tank up to 180-200 f ,2)do not use more than 40-50 psi....3)keep heat it under pression till you can see the tank expand a little .4)Remove the heat when you see the tank expanded JUST a little,let it cool off but still under pression...Do not go above 220 f ,do not use too much pression!
Kyosho MP9,OS. based engines,Hitec servos,Spectrum radio system,M2C clutch,Avid bearings.....my name is Gabor which is a Hungarian name:Gabor means Gabriel so just call me Gabe...
gabor szilagyi is offline   Reply With Quote
Old 05-20-2011, 08:13 AM   #17
Originally Posted by Frank L View Post
I added 2 odonell large filters to the line and ran it over the steering servo and around the front. That came up to 123.5cc. The Durango tank is seriously under capacity though.
Frank,
Care to show how you mount those 2 filters up?
Cheers
Sleepstream is offline   Reply With Quote
Old 05-20-2011, 10:28 AM   #18
On my Durango, with an external RB fuel filter and Dubro fuel line (routed as follows), I measure about 123ml (measured with measuring cylinder and full fuel line).... Is a 1st run kit....
Jaf1977 is offline   Reply With Quote
Old 05-20-2011, 11:22 AM   #19
How do we put 2 of those bad boys there? Pretty skint on space..
Old 05-20-2011, 11:46 AM   #20
You could probably mount the 2nd on the top of the radio box and take the fuel line round the back of the engine to the carb....more than likely will be over capacity then though...
