Old 05-18-2011, 07:37 PM   #1
NorthCentral RC's Avatar
Default Starter Box Question
Does anyone know what starter boxes will work with a Losi 8T truggy? It is the original rtr version. I am looking to help out a friend who always seems to have problems with the roto start thing. I know my blue ofna truggy box will not work but if anyone knows which ones will work without having to change anything on the motor and without grinding a bigger hole in the chassis I would appreciate the inout.
NorthCentral RC is offline   Reply With Quote
Old 05-18-2011, 08:36 PM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
Any starterbox out there will. I would suggest the ofna truggy box, it seems to set the standard for starter boxes.
Old 05-18-2011, 08:51 PM   #3
ohh EPiC FAiL's Avatar
Trader Rating: 51 (100%+)
i use the ofna truggy box for my 8ight 2.0 buggy... it will work for anything including the 8ight T. you just have to adjust the posts properly
TEAM FEARLESS RACING
I Race: Losi 8ight-E 2.0
I Crawl: XR10(almost VP10)
I Support: Futaba--Holmes Hobbies--Savox--Castle Creations--Tekin
ohh EPiC FAiL is offline   Reply With Quote
Old 05-18-2011, 09:01 PM   #4
Titian2010's Avatar
Trader Rating: 73 (100%+)
I'm not sure if this is his problem but my ofna box didn't work at first and it was because the wheel was to wide. Had to buy another ofna wheel that would reach up in my chassis. Other than that the 1.0 truggy should work on any 8 scale box. I use to use my friends 2.0 losi buggy box. Just position it correctly. Also if he's using the Mach 427 with roto start, tell him the back plate of the losi 454 will work on it.
Titian2010 is offline   Reply With Quote
Old 05-18-2011, 11:03 PM   #5
steve307b's Avatar
Trader Rating: 23 (100%+)
Also if its the 1.0 rtr, along with the engine back plate he will have to get different motor mounts to lower the engine closer to chassis. The race roller 2.0 mounts are on ebay all the time for a few bucks. I used the ofna truggy box with the 1.0 with no prob
8ight-T 3.0 **FX Royal Engine** 2013- Savox 1267/Hitec 7950
Henchman racing
DX4R
steve307b is offline   Reply With Quote
Old 05-18-2011, 11:05 PM   #6
Ofna is the only way to go.
TEAM BFL Banned for life
Sparky4u is offline   Reply With Quote
Old 05-18-2011, 11:49 PM   #7
Titian2010's Avatar
That is right! That's why I had to get the back plate put on. The flywheel was to high. I also remember trying the race motor mounts. I think the black back plate cause the motor not to go on with those mounts. It's a blur but I remember having an issue.
Old 05-19-2011, 05:56 AM   #8
So if he gets the 454 backplate, will it bolt right on or will the crank have to modified in any way?
Old 05-19-2011, 10:30 AM   #9
Titian2010's Avatar
From what I remember, I had to tap the crank forward from the inside. It was nothing big. The part is made for the mach. If u check ebay or ask your local hobby shop to pull the part numbers they will be the same. You might not need to tap it. Could of been my motor. If u do need to, don't go crazy and bang it. Light taps and it will move. Maybe some one else can help. It was a while ago with that motor and it's a bit of a blur.
d8 and d8t starter box question aptyk88 Nitro Off-Road 7 04-12-2010 01:44 AM
Starter box question??? Tate72 Nitro Off-Road 24 10-03-2009 08:29 AM
losi starter box question losi_racer Nitro Off-Road 15 05-21-2009 06:20 PM
DM-one or GT2... + starter box question - want your input! ScudMan Nitro On-Road 48 11-05-2008 07:54 PM
ofna chrome top starter box question svo Nitro Off-Road 17 05-07-2008 04:40 PM
