Old 05-11-2011, 08:08 AM   #1
Suspended
Default rc8b on/off switch
Hey guys i had a problem this past weekend, i lost my on/off switch. not literally its still there but my battery sizzled for some reason and screwed up all my 3 lines coming out of the on/off switch.
what do i do now? I do still run by direct connecting the cables for battery but its kinda trash to me to not have that fixed.
i cant find parts for it, am i naming it wrong? actually i dont even know the name so...
any help in advance id appreciate.
thank you.
dj
jonebonekc is offline   Reply With Quote
Old 05-11-2011, 08:18 AM   #2
metalartcustoms's Avatar
this otta work for it.... most of the switches seem to be universal, so if you go to like amain or nitrohouse, just search for switch....
http://www.amainhobbies.com/product_...ging-Connector
http://www.nitrohouse.com/p18486/SWI...duct_info.html
the JR one is probably the best out there with the charging cord hooked up, makes life very easy
BLAKE VANDERMEER
www.RACETEEZ.com - raceteez@gmail.com
Speed Passion - Venom - AKA - Boca Bearings - Avid - FTW
metalartcustoms is offline   Reply With Quote
Old 05-11-2011, 08:25 AM   #3
mgtmadness2007's Avatar
Almost any switch will work.
http://www.amainhobbies.com/advanced...itches&x=0&y=0
I spray my switches to keep them clean with denatured alcohol or simple green.
George White
Bath, NY
Team Terribles!
Race Vehicles-SC8 w/ GRP .28 Tuned,RC8T FT-Reedy VR 121 .21, 2035 pipe, RC8B-Reedy .21
http://www.jerrysrcraceway.com/
mgtmadness2007 is offline   Reply With Quote
Old 05-11-2011, 08:30 AM   #4
My favorite switch. I have used several and this has been the best with lipo.
http://www.amainhobbies.com/product_...2pin-connector
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-11-2011, 08:38 AM   #5
FLHX1550's Avatar
thank you.
dj
Best switch you can use is to eliminate the switch entirely. Use a good set of plugs and just plug in before you race and un-plug when done.
I myself use Deans Ultra Plugs (been around in electric forever, and can take the beating of off-road)
http://www.amainhobbies.com/product_...ra-Plug-1-pair
The switches made by the radio manufacturers are not really made for a dusty-off road environment, and I myself have had too many fail me too many times. Also, these switches and their wires really aren't made to handle Lipo power. If you will notice, the wire on a Lipo RX battery is about 2x as big as the wire on the switch.
JConcepts - TKO - RW Mods - B-Fast - MODX Motors & Batteries - Skare OCD Designs
FLHX1550 is offline   Reply With Quote
Old 05-11-2011, 09:07 AM   #6
Suspended
ok so i just take out those 2 small screws on top and can easily swap out switches? nice
Old 05-11-2011, 11:06 AM   #7
tc5 man's Avatar
the best on/off switch is no switch just a direct connetion with deans plugs.
i, use regular deans plug you do have to cut open the receiver and battery box to make it wider or you can use mini deans.
the, only way switches ever last is cleaning them every time your done racing its not worth it.
jonebone: yes, you unplug the switch from the receiver and the battery and than take the two screws out of the switch and that should be it.
and than unsolder the wires on the circuit board on it and leave the reciever plug on it.
tc5 man is online now   Reply With Quote
Old 05-11-2011, 11:16 AM   #8
omarwashington's Avatar
just use a switch boot like this so you don't have to clean it
RCCARS!
omarwashington is offline   Reply With Quote
Old 05-11-2011, 11:23 AM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
Why not going for the KO one touch button electronic switch?
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 05-11-2011, 12:30 PM   #10
dont most chassis come with these?
Old 05-11-2011, 02:39 PM   #11
I have used micro deans plugs and eliminated the switch, very easy to run and not bulky. Never had an issue.
http://www.amainhobbies.com/product_...ized-Connector
Hot Bodies D8t- Clockwork JL 21/ AB mods C6, JP-1, Spektrum DX3R, JR servos, AKA tires
Hot Bodies D8- RB WS7 III, GRP 2053 pipe, Spektrum DX3R, JR servos, AKA tires
Losi 8t 1.0 mostly upgraded to 2.0 via ebay- RB C5, dynomite 086, spektrum DX3S, orion servos, AKA tires
Muggified LST- Teal head 427, RD logic pipe, JR servos, panther tires
morkendi is offline   Reply With Quote
Old 05-11-2011, 06:53 PM   #12
RMKinWI's Avatar
Trader Rating: 15 (100%+)
The RC8 receiver box is too shallow for some switches like the above Futaba switch. You need to look for a shallow switch (top to bottom height). I use the JR Sport Switch, with the Hot Bodies switch boot. The switch will not hit the bottom of the receiver box causing switch failure. You will need to enlarge the switch hole to use the boot. The boot also acts as a shock absorber so don't over tighten the 2 little switch screws. No matter what anyone says there is nothing easier than using a properly setup switch. And always mount the switch so ON is forward - so when you hit something hard it won't turn off. I race every weekend - both truggy and buggy and have never had a switch fail in my RC8's.
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Traxxas Slash 4x4 Thread Mach Nine Electric Off-Road 6252 08-05-2017 06:58 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
D8 OR RC8B??? kman16jr Nitro Off-Road 213 08-21-2010 10:38 PM
Team Assosciated RC8B (1 run) B-quick R/C Items: For Sale/Trade 11 11-09-2009 05:43 AM
