Old 05-08-2011, 03:56 AM   #1
Default how do i get a burred screw out
hey guys i have a 1/8nitr buggy and i burred one of my grub screws on the brake linkage, how do i get it out? also it is in there really tight
marto1996 is offline   Reply With Quote
Old 05-08-2011, 04:44 AM   #2
aussies1129's Avatar
Trader Rating: 74 (100%+)
you have got to some how get a hobby tool ie dremel with a thin cutting wheel and cut a groove so you can use a flat head screwdriver
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 05-08-2011, 07:02 AM   #3
You could also use a small easy out bit. That's what I do when a dremel wheel won't fit.
bevofrancis is offline   Reply With Quote
Old 05-08-2011, 07:06 AM   #4
Trader Rating: 22 (100%+)
Break out the torches!
j/k the dremel with small cutting tool works like a charm, make a small cut and then use your thin tuning screw driver to unscrew it.
sand geek is offline   Reply With Quote
Old 05-08-2011, 07:39 AM   #5
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
you guys really need to get this slut the screw out your head we all have cordless drills at the track easy out that stuff
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 05-08-2011, 08:21 AM   #6
merdith6's Avatar
Default Set screw guys
It's the little set screw that holds the brake arm on. Just drill it out with a small bit and be gentle, you may have to replace the brake cam or whatever it's called if you can't get the setscrew pieces out of the threads.....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 05-09-2011, 01:00 AM   #7
thanks guys, also if u wanted to know its the little scrw that is in that silver thing that compresses the spring for the breaks
Old 05-09-2011, 06:53 AM   #8
scwrod's Avatar
I call it a collar. You may have to cut it off and just get new collars. These grub screws are easy to strip out or cross-thread from over tightening or worn out hex drivers.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 05-09-2011, 07:57 AM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
That's one crazy screw. A slut screw. Hahaha you must be using an iPhone it does it to me all the time.
