Old 05-01-2011, 06:46 PM   #1
Brushlessboy16's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Brushlessboy16 Send a message via Yahoo to Brushlessboy16
Default What do you tune first?
If your at a race, and your car is not handling the way you would like it, what do you change and in what order?
-aside from tires.
Out of curiousity, I get kind of flustered knowing that two adjustments can accomplish the same thing .
Ben White aka The Flyin' Flashlight
Rc-monster Team Driver
JQ The Car, Neu 1515 1.5D, Mamba Monster, Rc-monster slipperential, Futaba Bls351
Unconventional Techniques, Superior Results.
Brushlessboy16 is offline   Reply With Quote
Old 05-01-2011, 07:01 PM   #2
madac's Avatar
I usually start with tuning my engine and getting it running at it's best. Then I can tune the suspension, droop and choose tires for track conditions to go faster with my already tuned engine. Just how I do it and I'm sure others do it other ways but this works for me.
Team Associated B5
Spektrum DX3S
madac is offline   Reply With Quote
Old 05-01-2011, 07:18 PM   #3
thenova70ss's Avatar
Trader Rating: 52 (100%+)
I start with Tires find the tires that work best and then go to the shocks and then camber and then Toe and after all that diffs. But most of the time you can get the car handling better with Shocks and Camber diff is the last thing i touch.
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 05-01-2011, 07:20 PM   #4
Guest
Same thing here!
LOSIRACER77 is offline   Reply With Quote
Old 05-01-2011, 08:19 PM   #5
after tires, I useally go to ride hieght, droop, camber, and toe. Then roll center and fluid changes if needed. I think weight transfer when tuning. For example, need more on power stearing, you need to make wieght stay more over the front tires and not shift so far back. I have a good setup, so I rarely change anything but ride hight and tires and accational rear roll center.
Hot Bodies D8t- Clockwork JL 21/ AB mods C6, JP-1, Spektrum DX3R, JR servos, AKA tires
Hot Bodies D8- RB WS7 III, GRP 2053 pipe, Spektrum DX3R, JR servos, AKA tires
Losi 8t 1.0 mostly upgraded to 2.0 via ebay- RB C5, dynomite 086, spektrum DX3S, orion servos, AKA tires
Muggified LST- Teal head 427, RD logic pipe, JR servos, panther tires
morkendi is offline   Reply With Quote
Old 05-01-2011, 09:25 PM   #6
engine/pipe has to be right and a priority, i am going to lump clutch and gearing in here with it depending on the traction can be a powerful tuning aid.
Tires, tires, tires
ride height/droop/shocks.
diff tuning has helped alot some times, only problem is it's a pain and if it doesn't work and you need to change again it's a tripple pain.
A turn or two of preload can have a dramatic affect sometimes. springs and oils too.
But most of the time tires/clutch/suspension will give me the most help.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-01-2011, 09:56 PM   #7
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
if you know what change do what do what easy first
so you need more steering what can you do
go to a softer front bar
go inside on the arm on the shocks
go down one spring rate
drop your ride hight a mm up front
change your toe out a lil
so i start with ride hight and go run it again
then i change the toe
then i say is the spring going to help or should i try the arm first
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 05-01-2011, 10:56 PM   #8
johnny t's Avatar
Every brand if car us a little different in what is the go to setup stragedies. Some respond better or worse (or not at all!) to different changes. I don't know your racing history so please forgive if you may already know these things.
You have to prioritize what setup changes can be accomplished with what time you have available. Something that is not the ideal thing to do right away like ride height change, is valuable if all you have is minutes before a race. And you are trying to compensate for changing conditions.
More ideal things to change, like suspension geometry, Take more time of course. But can provide real powerful options. That is, if you know what they do for your car and driving Style. Here is the rub, and the answer you may not want to hear, but is all about test test test. Dedicate practice days to just
constant changes to roll centers and arm angles. Just so you know what they
do, know them like the back of your hand and help make the right guesses race day.
That being said, yes, two different adjustments can accomplish similar things but often with very different adverse consequences. Every positive change you make will have a associative negative side effect. So when deciding between different options you ask your self which ones side effect will give you lesser problems, and can you fix that with some other change. It's possible the side effect may well be irrelevant not needing to compensate.
Maximize gains, minimize losses, repeat.
Roll centers, swaybars and shocks are the main things I adjust. Kickup angles too if there is time. And the more you know your shocks the better, as they are the gate keepers between the tires and chassis geometry. Real bummer if there is bad communication there.
I am incredibly lazy, so one thing I do is keep multiple upper links assembled at my default camber settings. So comparisons or changes between heats are actually doable.
Also a second set of shocks, so comparisons can be made. And during racing allows a quick "undo button" if a shock change does not work out.
Those two investments will get you a faster car before any fancy pipe and motor.
johnny t is offline   Reply With Quote
Old 05-01-2011, 11:27 PM   #9
tc5 man's Avatar
-aside from tires.
go with a rc8t if you need more steering
but what i do if needed is usually just mess with the "shock angles" or "camber" "tires" ride height not to much really.
Old 05-02-2011, 06:17 AM   #10
jmaxey51's Avatar
aside from tires, its usually droop and/or ride height for me, that is about it. every now and then ill change rear diff between 2k and 3k.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 05-02-2011, 06:40 AM   #11
-aside from tires.
There are sooooo many things you can change. It really depends on what it is or is not doing.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 05-02-2011, 07:50 AM   #12
portyansky's Avatar
Trader Rating: 54 (100%+)
Hudy Off-Road setup guide. http://www.teamxray.com/teamxray/sho...p?file_id=4461
I know this book in and out, but it never leaves my tool box. No one can tell you what to check 1st, b/c no one knows you or your car. You will have to run your car and figure out whats happening and what it needs to get better. If your car is handling like total poo. I would find a base setup for that car. Run it on the track and adjust from there. BUT and I cant stress this enough, change 1 thing at a time. I know changing one thing at a time will take you longer to get there, but you will know if you are heading in the right direction and what makes the biggest change.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 05-02-2011, 11:23 AM   #13
marshon50's Avatar
Default +1 On Hudy
Hey Ben, after looking through the Hudy set up guide I broke it down and summarized in order of preference. First things first is tires. Tires are 90% of setup so if they're wrong, nothing else is really going to fix it!!! At Families it's easy, Holeshots, Digits, Sevens, Turbotrax, (not sure of AKA's small pin, but just ask Gregg/Gunnar). Run what the fast guys run or find the closest equivalent in your tire selections.
So after tires here goes the Hudy summary:
1. Downstops (droop)
2. Ride Height
3. Camber
4. Track Width
5. Caster
6. Toe
7. Ackerman
8. Steering Servo Preload
9. Bump Steer
10. Roll Center
11. Shock Absorbers
12. Front Kickup
13. Rear Anti-squat
14. Wheelbase
15. Anti Roll Bars
16. Rear Wing
17. Clutch
18. Diffs
19. Gearing
20. Tires, GET THE RIGHT ONES FIRST!!!!!
Thank you sponsors:
Werks Racing, 30% Race Blend Nitro Fuel, Werks B6 and Pro, B5 and Pro, B2, Pro Clutch
Hobby Pro USA, Agama USA, VP-Pro, Beta Racing Tires
Hobbymasters, Red Bank, NJ
Venom Group
marshon50 is offline   Reply With Quote
What do you guys think of this Werk's .21 Engine? Garet Jax Nitro Off-Road 82 07-20-2016 04:40 AM
WHAT DO YOU THINK ABOUT THE LOSI MACH 427 pimptasticksilk Nitro Off-Road 31 03-23-2014 05:34 PM
Riped off on a engine? What do you think? dayglo33 Nitro Off-Road 69 06-24-2010 05:57 AM
Setup - what do YOU work on first? sosidge Electric On-Road 7 12-08-2008 09:44 AM
