Old 04-29-2011, 05:51 PM   #1
Suspended
Trader Rating: 7 (89%+)
Default New to nitro
I'm new to nitro and I just picked up an Ofna Ultra LX it hasn't been run in 4-5 years. everything seems to be in working order I just took the motor out to bring to my lhs. Is there anything I need to know about this buggy? Should i rebuild the diffs?
phathedrc18t is offline   Reply With Quote
Old 04-29-2011, 06:19 PM   #2
Trader Rating: 24 (100%+)
New to Nitro or not, It dosent matter what kind of 4-5 year old not driven buggy it is either. You should go through the whole thing to see if it's even worth rebuilding what it needs.
got_nitro is offline   Reply With Quote
Old 04-29-2011, 08:40 PM   #3
rangerjkb's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to rangerjkb
+1, I would recommend taking it all apart, check everything, refill diffs-shocks, check all parts for integrity, reassemble and reset all adjustments to recommended specs. Then you're off to having some Nitro fun!
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 04-29-2011, 08:58 PM   #4
sickstang84's Avatar
ya i agree with them i would definitely go threw the whole thing and bring all your factory settings back
Extreme Fox Body Mustangs check us out on face book !
RC18B2 exotek battery strap and shock towers associated anti roll bars
future plans reedy 9500kv brushless kit
sickstang84 is offline   Reply With Quote
Old 05-01-2011, 07:15 AM   #5
Trader Rating: 30 (100%+)
Only issue I ever had with that buggy was the front and rear diff ring gears. The stock ones are cast, and they suck. I tore them up almost immediately. When you re-build the diffs, do yourself a favor and buy the hardened steel diff ring gears and throw them on there. I went through about 5 or 6 stock ones while I tried different shimming. Nothing worked except the steel ones.
Check your usual wear components like clutch, shocks and bearings. For sure, replace clutchbell bearings. You will want to do this at least once per gallon of fuel, if not sooner.
If the buggy is that old, you will want to replace the fuel tubing and probably the fuel tank as well. Nothing will be more frustrating than trying to tune an engine with an air leak in your fuel line or tank.
Axial Wraith
sdtech58 is offline   Reply With Quote
New to Nitro, What to get djtomczak678 Nitro Off-Road 34 12-29-2010 05:12 PM
having problems with my tmaxx/new to nitro bdyman Monster Trucks 40 09-19-2010 07:26 PM
New to NItro Onroad ausman123 Nitro On-Road 12 05-09-2008 05:45 PM
New to nitro rc sk8boarder Rookie Zone 30 11-28-2007 12:57 AM
new to nitro world, just got HPI RS4, upgrades? johnnyyd Nitro On-Road 35 02-28-2003 07:10 PM
