Old 04-28-2011, 12:10 PM   #1
Default Losi vented shock caps and foam
Does anyone else have issues with these? There is no way to set like more than a third rebound(if that) without them hydro locking when fully compressed. I've tried half foams "shaped" like drake says, full foams, quarter foams...it just doesn't work as advertised. Now my buggy that doesn't have vented caps...set the rebound just like drake says in the you tube video minus the foams and vented caps and bam perfect and EASY. I hear a few guys at the track saying the same thing. What gives?
Gonna seal the vents tonight(unless someone can enlighten me)...I just don't see the point in this. Every other car manufacture doesn't run vented caps and foam.
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 04-28-2011, 12:34 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I've never had any issue with getting the rebound I wanted using the EU caps and foams. I cut the foams down to about 1/2 height and round off the bottom a bit. Build the shocks just like Drake shows in the video. Rebound is perfect every time, and better yet it never changes with the vented cap + foams. I don't know why you're having an issue with them...
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-28-2011, 01:08 PM   #3
Some others i talk to at the track are having the same issue.
My buggy that doesn't have vented caps never changes rebound...if i set them to 3/4 before a race and check them after a race they are still 3/4.
Byrons 30%
Spektrum
Old 04-28-2011, 07:37 PM   #4
VWVR6_T's Avatar
Send a message via MSN to VWVR6_T
Some times or must of the time it takes a few trays to get it right. Built it, play with the shaft back and forth for a few times let it sit and test again, if is not what you liking, take the cap off and do it again.
TLR 8ight 2.0 - Werks B5/2058 l Airtronics l Hitec l rev-rc.com l Werks Fuels l Sweep
TLR 8ight T 2.0 - Werks B5 Pro/2013 l Airtronics l Hitec l rev-rc.com l Werks Fuels l AKA
Ofna GTP l Hyper 8P Turbo
QUOTE by FLHX1550 "The Werks B5 is kind of a legend"
VWVR6_T is offline   Reply With Quote
Old 04-28-2011, 08:45 PM   #5
Cory Kerber's Avatar
Find some firmer foams. I spend over an hour trying to get it right with soft foam. I was at the point of throwing the shocks against the wall until i tried some firmer foams. Problem solved for me.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 04-28-2011, 08:49 PM   #6
losi_racer's Avatar
Trader Rating: 25 (100%+)
i had the same experience. I dont run vented caps because of it. I even had a pro losi guy build a whole set for me and they still we to bouncy and they didnt feel right.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 04-29-2011, 04:58 AM   #7
jmackani's Avatar
Trader Rating: 14 (100%+)
I posted similar observations about six months ago and I am staying with the stock caps now.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 04-29-2011, 07:00 AM   #8
Yup sealed the caps last night with alittle jbweld. Problem solved. Shocks easy as ever to get the rebound you want and feel smoother than they ever did with the foams.
Byrons 30%
Spektrum
Old 04-29-2011, 07:11 AM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
I bought the vented caps and foams and I liked it. Never had any issues. I did notice that you had to take a little rebound out of the shock it was like 90% rebound = 100% rebound. But worked for me.
Old 04-29-2011, 09:38 AM   #10
Blue Screw's Avatar
Send a message via AIM to Blue Screw
Did u install new bladders when u put on the caps and foam? they could be worn out... Also heres a trick if u have a old purple tc tire full height.. then take an old 10th shock body put it in a drill press an cut out ur foams.. theres stiffer... thats how we did it in test before they came out...
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 04-29-2011, 09:48 AM   #11
Trader Rating: 15 (100%+)
Same here! Unless you keep the shafts new, pistons smooth, and fresh o-rings in the shocks the rebound sucks with vented caps. I'm not a fan.......to each his own I guess.
Jonathan Bell is offline   Reply With Quote
Old 04-29-2011, 09:59 AM   #12
Agreed...that would be probably the only way to come close.
Byrons 30%
Spektrum
Old 04-29-2011, 03:31 PM   #13
jwcobra03's Avatar
Trader Rating: 69 (100%+)
I told you so!!
Kyosho TKI3/BCE/ XZB Speed
Kyosho TKI3-E/Tekin 1900
Kyosho RB6/Orion R10 Pro-VST 7.5
Kyosho ZX6/Orion R10 Pro-VST 6.5
jwcobra03 is offline   Reply With Quote
Old 04-29-2011, 04:54 PM   #14
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
You Mean you covered the vent hole with or without using the foam. Why would U cover the vent hole were U still having problems before installing the foams?
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 04-30-2011, 10:27 AM   #15
I sealed the vent hole and run no foam like a stock shock now. Better for me.
Byrons 30%
Spektrum
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46468 03-20-2017 08:56 PM
Team Losi Malaysia News, Supports And Discussions mira5489 Malaysian R/C Racers 486 01-20-2014 04:38 AM
New Losi 8ight 2.0EU Buggy guss2009 Nitro Off-Road 96 01-03-2012 01:32 AM
Losi EU edition does not sell in Europe :))) Emmeth Electric Off-Road 16 04-17-2010 11:56 AM
