Help!! Lot of wobbling in 8t 2.0 wheels under on power steering
hello guys all of my endpoints are set correctly to maximum throw they can go to and it steers great off throttle. however when i begin to accelerate in or out of a turn the front wheels wobble terribly and it seems like it wants to go back straight. what i have done so far is change the rod ends and balls. some were sloppy but still no fix. also i notice the ackerman has a bit of play on one side so i went and ordered the king headz ackerman. i am hoping this helps. any other suggestions would be greatly appreciated. oh and also turning right seems to be worse than the left.
Originally Posted by thekisscutken1
(Post 9021591)
i run my servo saver at 2 1/2 turns out from fully in. is that too far out? i am running a hitec 7955tg servo
Servo saver. Tighten it up! And if it's already tight you may need to replace the saver. What you're experiencing is definitely from a loose or worn out servo saver.;)
http://www.amainhobbies.com/product_...ank-Plastic-20 |
just how tight should i go with it?
I tighten mine up all the way. The one on my car is good for about 5 or 6 race weekends then it starts to get sloppy. Some brands last longer than others.
(Post 9022743)
(Post 9022743)
I would replace. I would not advise running your servo saver all the way tight. Its made to protect your $100 servo. |
have you check your bearings?
Originally Posted by token
(Post 9026309)
so after weeks of trying to figure out what was causing all this i found out the the front a arms were both wobbling terribly and it was caused by both bolts going through front bumper and into front gearbox being broken in half!! installed new front gear box and screws and no more a arm slop!! cant wait to try it now. should def be the fix right
(Post 9026873)
you know what i'm talking about? anyways it caused massive amounts of a arm wobble. basically the bolts were broken in half and barely holding the front end together
Those same screws kept comming lose on my 8ight T and it was wobbly like your buggy on power. Gotta keep an eye on another thing now.:flaming:
Well at least you got it figured out.
