Old 04-25-2011, 07:33 AM   #1
Suspended
Trader Rating: 1 (67%+)
Default Thread locker
What color thread lock should i use on my d8
Hot Bodies Racing, Proline Racing, Byron Fuels, and Radio Post
-Hot Bodies D8 Hara Edition, and D8 Truggy
-B5 and b4.2
rcgarrettp9 is offline   Reply With Quote
Old 04-25-2011, 08:34 AM   #2
BLUE. Only use red on stuff that is supposed to never come apart.
cbonner99 is offline   Reply With Quote
Old 04-25-2011, 10:06 AM   #3
ScottyM's Avatar
Trader Rating: 27 (100%+)
Blue Loctite, and get the GEL. It doesn't spill and works just as well..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 04-25-2011, 11:22 AM   #4
Integra's Avatar
But doesn't last nearly as long. A liquid bottle can last Year's Vs the Gel which is Month's. (I guess pending how much you wrench)
Old 04-25-2011, 11:49 AM   #5
l3asher's Avatar
I been on the same bottle of gel for a long time, you don't waste as much.
l3asher is offline   Reply With Quote
Old 04-25-2011, 12:25 PM   #6
Integra's Avatar
I wrench alot i guess. I never found the gel to last much past a couple 3 or so month's before i was opening the tube to snatch up some more. Ever since buying a Large luquid bottle (Sure it was 20$+) But Im still not 1/2 was through it in a Year+. So By my standards the Liquid is the way to go.
PS Don't cut such a large hole in the tip and you wont have it oozing all over the place.
Old 04-25-2011, 12:58 PM   #7
THE PHILLY JYNX's Avatar
I use the permatex blue gel.I have 2 race seasons on one tube.The reason I use gel is because i do not put locktite on the threads.I put it on the angles part of the flat head screw that comes into contact with the chassis. Tighten them down and wipe off any excess. It drys and makes a nice seal that keeps the screws from vibrating loose or tighter and it keeps them from backing out. Gun smiths use this method when attaching rails to receivers and rings to bases. Also screwing the stock to the action when the rifle is pillar bedded. Even with the losi motor mount screws and washers I use this technique and have not had an issue since doing so.I put it on the screw and the back side of the washer....just make sure everything is clean and you will be good.
BuKu Performance Products
S&W Fuel
Team Sweep Racing Tires
AbsoluteHobbyz VP-PRO
THE PHILLY JYNX is offline   Reply With Quote
Old 04-25-2011, 04:46 PM   #8
THis makes total sense, since it is anerobic, im going to try this method. Im currently race preping mine to get ready for some 2 hour test sessions.
Mugen Seiki : HiTec RCD : Proline : Upgrade RC : Walden Designs : Byron's Original
www.prospeedrc.com
www.facebook.com/prospeedrc
Speedracer1600 is offline   Reply With Quote
Old 04-25-2011, 04:50 PM   #9
Get the blue one and shake the bottle before using.
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 04-25-2011, 04:54 PM   #10
I use the stick. Haven't had any issues with it. Don't have to worry about drying out, getting hard or leaking.
Old 04-25-2011, 05:16 PM   #11
Keith Lewis's Avatar
+1
I use the stick loctite. It seems to work the best for me and lasts a long time. It just seems harder to find than the liquid in stores.
Keith Lewis is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
