Old 04-23-2011, 02:06 PM   #1
Default Toe In/Toe Out Question
I have read what Toe In and Toe Out does to the handling aspects of the car, but I have seen several instances where one wheel is straight and the other is pointed outward.
Is there a purpose for this type of setup? Or is this a mistake?
Thanks for the input
tk1931 is offline   Reply With Quote
Old 04-23-2011, 02:08 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Its a mistake. when you turn on the RX the tires should have equal amounts of toe on both sides.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-23-2011, 07:56 PM   #3
Thanks, I was wondering why this would be.
Old 04-24-2011, 02:44 AM   #4
Uga
Uga's Avatar
There could also be a play in the steering rods which is normal, so standing still it could look like each wheel has a different angle, but actualy when running on track both wheels will tend to take the maximum negative position. To adjust toe, push the wheels as wide open as it allows with your fingers.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 04-24-2011, 05:17 AM   #5
Default Measuring Toe
I know that you can measure toe angle with setup boards such as Hudy but they are expensive, and I also believe that RPM makes a gauge as well although it probably is not as accurate by much more reasonable in price
Are there other effective methods for measuring toe angle?
Old 04-25-2011, 07:16 AM   #6
Ola
Ola's Avatar
I use a camber gauge to adjust toe in/out.. I just use a long flat piece of metal/wood that goes across the entire car width + 2" outside both sides.. I hold this piece against both wheels, and measure the toe angle between this piece and the wheel, horisontaly..
Ofcourse, the servo/power has to be ON first.
I usually double check sub trimming, and servo horn position to be correct before i start adjusting.
E-revo cc1717 ++
RC8T FT CE v4 CC1520
Ola is offline   Reply With Quote
Old 04-25-2011, 05:33 PM   #7
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
+1 it's a mistake, you'll want each side to be the same.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 04-25-2011, 05:45 PM   #8
Spads11's Avatar
Trader Rating: 27 (100%+)
Even if there is play, it should still even out to be the same right?
D. A. DeRouen, TSgt, USAF (ret.)
JQ Racing Team
THECar WE LV, Reds, Savox
ProLine! Upgrade RC!
Spads11 is offline   Reply With Quote
Old 04-25-2011, 05:48 PM   #9
Spads11's Avatar
Thumbs up
Hudy and JQ both have outstanding setup guides that talk about all the adjustments that can be made.
JQ Racing Team
Old 04-25-2011, 08:55 PM   #10
I think I am following you...I am assuming "this piece" is the camber gauge?
Old 04-26-2011, 10:58 AM   #11
Ola
Ola's Avatar
Sorry, language problems
I ment you measure the toe angle, against the wood/metal "piece" that you run across the width of the car..
If you got 0` toe, this will be at a 90dg angle of the wheel, comprende?
E-revo cc1717 ++
Old 04-26-2011, 12:10 PM   #12
krash'um's Avatar
It looks like a mistake but if you turn on your receiver and transmitter and center it, it will show that you have equal amount of "toe out" if not it's just slop that's giving the illusion.
Toe out in the front increases your steering response when entering turns and increases straight line stability but will take away some on power steering.
May the fastest be the fastest!
krash'um is offline   Reply With Quote
Old 04-26-2011, 12:41 PM   #13
skittles's Avatar
Hey,what u could do is,first decide whats your toe in/out angles u desire(usually measured in degrees) use the turnbuckle wrench and adjust both sides,make sure u make even turns on both sides..then use a ruler or vernier caliper to measure the toe angles (measure from the inner part of the rim to the other inner part of the rim) right to left..if its not right,then do ur adjustments again..base from what i know,2 degrees is approximately 1mm..lastly,measure your turnbuckle on each sides to make sure its even,hope this helps..
skittles is offline   Reply With Quote
Old 04-26-2011, 06:31 PM   #14
I understand now thanks for the advice.
Old 04-26-2011, 06:32 PM   #15
Good advice....thanks
Custom 4* toe in alum and steel squat blocks for all b4/t4/sc10 guys! look inside chedda bob R/C Items: For Sale/Trade 212 11-29-2014 12:55 AM
Rear toe-in on brand new TC3? Fast20v Electric On-Road 6 06-18-2006 01:16 PM
in-board or out-board Toe-in benoitrdv Electric On-Road 10 07-28-2004 03:06 PM
