Old 04-23-2011, 12:36 PM   #1
warnked's Avatar
Default how often do you wash tires with water?
I am a little worried about my foams degrading if too much water gets inside. How do you guys get the mud off your tires? How often do you wash with water and how do you protect the foams?
AE B4.1 Worlds, Losi XXX-T CR, Tamiya F104, Jammin x1x, HPI rs4 evo+
warnked is offline   Reply With Quote
Old 04-23-2011, 12:41 PM   #2
JamminSP's Avatar
I usually wash mine after every heat and main with water and simple green IF the tires last that long. I spray them down with simple green then rinse off with water
Shawn Powers
::Special Thanks to My 2014 Sponsors::
Imbue Motorsports, Radiosistemi, RW Mods, Argus Engines, Radiopost
R.I.P Matt "Reaper" Powers 09/24/1953 - 10/24/2013
JamminSP is offline   Reply With Quote
Old 04-23-2011, 12:44 PM   #3
Send a message via AIM to Error404
I wash mine after every race.
Punch a hole in the tire. It'll allow water and dirt to exit instead of getting in there and ruining your foams.
Losi XXX-NT
Losi XXX-S
Losi 8ight 3.0
Error404 is offline   Reply With Quote
Old 04-23-2011, 01:55 PM   #4
MCR82's Avatar
+1 on the simple green & water method.
MMI - RC Hobbyzone - Mugen Seiki - Neo + Fuels - AKA Australia - M2C - Phoenix Hobbies
MCR82 is offline   Reply With Quote
Old 04-23-2011, 02:06 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
closed cell foams are waterproof...wash away...they will last longer than the tire no matter how wet you get them. If they are not closed cell then try not to get them wet at all..plug up the holes and brush off as much dirt and mud you can before using any kind of liquid
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-23-2011, 04:36 PM   #6
warnked's Avatar
thanks jaz, that sounds the best
Old 04-23-2011, 04:41 PM   #7
Jaz240's Avatar
Molded usually means they are not closed cell, but nowadays its its really hard to tell unless you are holding the foam in your hand. Closed cell foams feel more like a suede fabric than rubber. Find the foam you have online and it will tell you if it is closed cell or not.
There is basically 3 types of foam out now:
That original sponge type foams that looks like packing material
Molded foam to fit your tire and rim better
Closed cell, which last the longest and are waterproof
Old 04-23-2011, 06:12 PM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
I try not to wash tires. Just run a new set unless they are packed with mud then I will pull out a tire brush and do the deed.
Old 04-23-2011, 07:02 PM   #9
Brushlessboy16's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Brushlessboy16 Send a message via Yahoo to Brushlessboy16
Wheres your trash can, ill take the used ones
I Fill a bucket 10-1 water and simple green, dunk a hard bristled brush in it and scrub the tires, then dry them with a towel.
Ben White aka The Flyin' Flashlight
Rc-monster Team Driver
JQ The Car, Neu 1515 1.5D, Mamba Monster, Rc-monster slipperential, Futaba Bls351
Unconventional Techniques, Superior Results.
Brushlessboy16 is offline   Reply With Quote
Old 04-24-2011, 07:07 AM   #10
I wash 'em at the end of the day (two or three sets) BUT I also blow 'em off with air from the shop on an long screw driver in the center. They have holes that vent, but they clean out just fine. Plus I check the balance befor I run 'em.
The Working Man is offline   Reply With Quote
Old 04-24-2011, 08:31 AM   #11
Trader Rating: 30 (100%+)
I've got a scrub brush shoe-goo'd bristles up in the bottom of a small rubbermaid container. At the track, I fill it with water and a touch of simple green just to the top of the bristles, grab the dirty tires and scrub away. Works great!!
Axial Wraith
sdtech58 is offline   Reply With Quote
Old 04-24-2011, 08:59 AM   #12
Clean it with air while the dirt is still wet
Hemi Killer is offline   Reply With Quote
Old 04-24-2011, 12:56 PM   #13
j_blaze14's Avatar
Trader Rating: 34 (100%+)
holes in the tires help too. few revs on the starter box and they are pretty much dry inside.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 04-24-2011, 01:24 PM   #14
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Closed cell foams + holes punched in the tire = no problem.
Always punch holes in your tires, not the rims. Dirt and any water you get in will be flung out when running on the track.
If you're using old school cut foams or molded foams that aren't closed cell, just be careful not to get much water in them.
As for cleaning don't run them under water, or dunk them. Just use a scrub brush and a bucket of water + simple green to scrub them off. Then dry them off well with a towel.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-24-2011, 01:43 PM   #15
jmaxey51's Avatar
not true... closed cell foams do last longer but they DO degrade over time due to water, i re-used foams once and when i took them out to use again they were slowly falling apart....
+1, i think the biggest thing is to have NO hole in the wheel and just on the outside of the tire... most VP Pro tires come with holes already in the tire.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
TRF414M, 404x, 414, 414X TRF-Powered Electric On-Road 3575 07-22-2017 07:54 PM
what is a good substiture for air filter oil? dreaux Nitro Off-Road 49 06-20-2010 08:01 AM
How often do you give your car a FULL cleaning? CaptainHowdyt13 Nitro Off-Road 36 06-16-2009 01:08 PM
