Old 04-23-2011, 07:09 AM   #1
Trader Rating: 26 (100%+)
Default Shock Rebound Question
IKve watched the adam drake video on setting up your shock rebound, but it doesn't seem to be working for me. Even after I put the bladder on the shaft comes all the way out. It's almost as if the bladder doesn't form a tight seal. Could it be that the bladders are shot?
☆ Losi 8T 2.0 ☆ OS Engines ☆ VP PowerMaster ☆ AKA ☆ HiTech ☆ F-Bomb Graphix ☆
555 Raceway, Bartow FL - http://www.facebook.com/555Raceway - Be a part of the rebirth!
SDelaney is offline   Reply With Quote
Old 04-23-2011, 10:55 AM   #2
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Bladder do get really soft replace if you think its a problem cheap. Once U fill your shock pulse let them sit then push shaft up to the desired shock rebound. Place bladder and push oil should pour from the side then pull the shock shaft down a tad this will hold the bladder insuring no air. Air is your enemy this will cause frustrations and hydrolock.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 04-23-2011, 12:14 PM   #3
stallen50's Avatar
Trader Rating: 30 (100%+)
+1 with what big jay said
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Shock Rebound vwduud Nitro Off-Road 10 01-31-2011 03:24 PM
Shock refilling question.. SirJangly Electric Off-Road 10 04-26-2010 06:54 AM
