Old 04-23-2011, 02:20 AM   #1
Default Is it necessary to thread lock?
Hi guys
I race a losi 8 and generally do not use thread lock, even on metal to metal as I have had issues in the past with screws getting stuck. Is this a really bad idea?
Cheers
Ben
teamshaw is offline   Reply With Quote
Old 04-23-2011, 02:21 AM   #2
neobart's Avatar
In short, yes.
Metal to metal screws can very easily work themselves loose.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-23-2011, 02:41 AM   #3
j_blaze14's Avatar
Trader Rating: 34 (100%+)
i've heard of people using elmers glue as an in between. there are some screws you almost never touch and some that go in and out all the time. as long as the screw is clean going in it should stay in fine.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 04-23-2011, 03:50 AM   #4
Trader Rating: 20 (100%+)
Well look at it this way, u can either be the guy that shows up to the track and has confidence in his shizzy staying together OR u can be the guy standing on the drivers standsweating his nutz off waiting for something to come apart. Sounds to me like u don't like stripping screws everytime u need to take something apart, or u break. Tell u what to do bro, get yourself some nice quality mip thorp tools, all u really need is a 5/64 and a 3/32 -(and if u got extra coin the ball end for your engine bolts) and you will be set! In my experience they have been the best tools ten fold on my losi, they fit perfect, also a second great choice iv been using latley is dynamites cheap 15$ toolset that has I believe 4 or 5 perfect fitting tools like my mip thorp tools, they come with .50 1/16 5/64 3/32 and then another bigger size my losi doesn't even use so I never pulled it out, anyways those tools have been so much better then my previous tools it's sick. Some losi threadlock cause it has a good tip that doesn't make a mess. Horizonhobby.com !
Matt Piva is offline   Reply With Quote
Old 04-23-2011, 05:49 AM   #5
lanmine657's Avatar
you should always run thredlock(blue never red) on all your metal to metal connections, do not use it on the clutch pins, if you are stripn out stuff you need a better set of tools, I have always had good luck with XTM tools
Buggy on the Brain
MotoAdventure Kawasaki
LOSI
Riva-Sinister Skis-Jetworks-Jet Pilot
Coorslight
lanmine657 is offline   Reply With Quote
Old 04-23-2011, 09:05 AM   #6
captain america's Avatar
Hmm, never thought of using Elmer's as a thread-locking compound, but I think I'll try that. If anything it should be more user-friendly than nail varnish.
Oh, and Ben, the key is to use just a small amount of thread-lock on a screw; just barely enough to cover the threads on the bottom 1cm or so. More than that will just put unnecessary stress on your screws and tools when you come to unscrew them.
captain america is offline   Reply With Quote
Old 04-23-2011, 10:38 AM   #7
speedy2's Avatar
if you use threadlock
just use a very small amount, not a lot
it will be enough to stick the screw and will get loose again using a tool
also mount the screw in using less power, it will hold..and unscrew more easily
if you applie heat with a soldertool,the threadlock will soften up
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 04-23-2011, 02:10 PM   #8
MCR82's Avatar
I have always used the Factory team Associated thread locking compound.
Always holds screws in & never a problem removing them, just ensure you always use only a tiny amount...
MMI - RC Hobbyzone - Mugen Seiki - Neo + Fuels - AKA Australia - M2C - Phoenix Hobbies
MCR82 is offline   Reply With Quote
Old 04-24-2011, 06:37 AM   #9
mdempt's Avatar
Send a message via MSN to mdempt
i always use the blue removable threadlock just incase any screws come loose, especially around the engine since the vibration can work them loose.
mdempt is offline   Reply With Quote
Old 04-24-2011, 02:42 PM   #10
Nitro2002's Avatar
I use green locktite. Works fine so far.
Nitro2002 is offline   Reply With Quote
Old 04-24-2011, 02:49 PM   #11
jmaxey51's Avatar
if you have trouble getting screws out, you can heat it up a little bit to loosen up the thread lock. i do this almost always. also a good set of tools help also.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 04-24-2011, 03:01 PM   #12
bill marchant's Avatar
Trader Rating: 229 (100%+)
Send a message via Yahoo to bill marchant
blue loc-tite and Heat gun for me problem solved!
Hobby Pro USA, Agama
PRS1 buggy D3 13.5/Hobbywing
Novarossi/savox
BRUCKNER HOBBIES For All your RC needs 2 FEED YOUR ADDICTION!!!
BARNSTORMERS RC/Gun Hill Racing
bill marchant is offline   Reply With Quote
Old 04-24-2011, 04:26 PM   #13
PTP Racing's Avatar
I always use blue loctite on every screw going into metal even some of the ones into lock nuts. If you use it and you should remember not to crank down the screws too tight. With loctite they will stay where you leave them get them tight but don't muscle them too much and everything will work out very well.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 04-24-2011, 04:41 PM   #14
jammin32j's Avatar
I thought green was permanent?
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 04-24-2011, 04:57 PM   #15
aussies1129's Avatar
Trader Rating: 74 (100%+)
blue is the go its only med strength so you can remove and be careful using green I used it once as I had nothing else and was force to use a heat gun and a big tool to remove the screw
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Losi BK2/MF2 thread DerekL Electric Off-Road 2850 07-18-2010 10:59 PM
