Old 04-24-2011, 04:59 PM   #16
jammin32j's Avatar
Originally Posted by aussies1129 View Post
blue is the go its only med strength so you can remove and be careful using green I used it once as I had nothing else and was force to use a heat gun and a big tool to remove the screw
That's all I ever use is blue, I don't know how he is using green and getting the screws to break loose without stripping them.
VP Pro, Agama
Hitec-7955's, 3Pk----AKA Racing Tires
Absolutehobbyz.com____Dirtrc.com
O'Donnell, D.I.R.T. R/C ultimate Tire Gluer
Jeremy Davis
jammin32j is offline   Reply With Quote
Old 04-25-2011, 12:58 AM   #17
Nitro2002's Avatar
I don`t soak the screws in it but use a very little drop on each. The blue was better but all the shops were out of stock when I needed it.
I thought only red was permanent, just found out now that green is too
The worst one I`ve ever used was some HPI red thread glue though. Everything got totally stuck.
Nitro2002 is offline   Reply With Quote
Old 04-25-2011, 06:24 AM   #18
Blue and Red - Both come out with a little heat.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-25-2011, 03:14 PM   #19
mechanic77's Avatar
Well, to answer the original question....I would say it's not absolutely necessary. I'm not trying to start a pissing match, but I only use loctite on my flywheel nut and sometimes on steering links that tend to come loose. So far, after 5+ years of racing, I haven't had a dnf caused by a screw coming out. I will say that if there is any question in your mind, I would suggest using loctite (blue). I should also say that I constantly check the screws on my car between rounds too
Just my 2 cents....
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 04-25-2011, 04:38 PM   #20
There are two types of green one is a Wicking grade and the Other is a Sleeve locker. the permanent stuff is the Sleeve lockers its good for more or less .004" the wicking grade is about the strength of blue, another type you can use is VibraTite, you paint it on and it drys and then springs into action when installed. Make it nice if you plan ahead and coat the new bolts with it and store them.
Mugen Seiki : HiTec RCD : Proline : Upgrade RC : Walden Designs : Byron's Original
www.prospeedrc.com
www.facebook.com/prospeedrc
Speedracer1600 is offline   Reply With Quote
Old 04-25-2011, 05:00 PM   #21
Spads11's Avatar
Trader Rating: 27 (100%+)
Agreed, red is not really permanent, but stronger than blue.
D. A. DeRouen, TSgt, USAF (ret.)
JQ Racing Team
THECar WE LV, Reds, Savox
ProLine! Upgrade RC!
Spads11 is offline   Reply With Quote
Old 04-25-2011, 05:03 PM   #22
Spads11's Avatar
And, if you don't bother to thread lock shock piston screws, they will come out. It's a matter of time. Inevitably, it will be during your best qual!
JQ Racing Team
Old 04-25-2011, 05:32 PM   #23
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
+1 use threadlock on metal to metal.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 04-25-2011, 07:54 PM   #24
Over time you will realize what needs to be threadlocked and what doesn't. On my mugen, the post that hold the wing mount together, the servo saver shafts the pipe hanger and grub screws holding my cvd's. that is it.
I never put them on my engine mounting screws, that get PLENTY tight enough. And you only need a VERY small amount. I have had the same little losi bottle for 2 years and it is still only half empty. One very small drop and dab the excess on a rag or shake it off.
And NEVER i mean NEVER put it on the end of a crankshaft.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 04-25-2011, 08:01 PM   #25
rider313's Avatar
Trader Rating: 94 (100%+)
What some guys need to remember is we are working on 1/8 scale cars and trucks here. That means 1/8 the amount of thread lock on the screws compared to 1:1 car bolts and nuts. It doesn't take much thread lock to hold screws in there and they are easily popes loose with a driver without stripping. Just a lil drip on the end threads and thread it in and your good.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 01:30 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Losi BK2/MF2 thread DerekL Electric Off-Road 2850 07-18-2010 10:59 PM
