Old 04-20-2011, 11:04 PM   #1
Trader Rating: 25 (100%+)
Default Diff cleaning
What do guys use to clean your diffs? I am looking for something that will help dissolve the diff oil. I run 1/8 oval and we really thick fluids. Getting all the fluid out and off the gears is a real pain. Have you guys found anything that works. I personally use 125k fluid in the front and center and 10k in the rear. It makes the car work, but also me while cleaning and changing oils. Thanks for any and all help.
plumbcrazy is offline   Reply With Quote
Old 04-20-2011, 11:08 PM   #2
TEXT's Avatar
Umm probably your average nitro cleaner should do the trick...i really try everything like Goop that doesnt have the sand and also like WD40 sometimes will help get some of it off :/...those are my methods but im sure there are much better ones out there !!
Tamiya VDF2
Spektrum DX3s Radio
Homemade ABS Drift Tires 2" piping
Off-brand fluorescent orange rims
Toyota AE86 body (white w/sharpie marker)
TEXT is offline   Reply With Quote
Old 04-21-2011, 12:09 AM   #3
JsK
JsK's Avatar
I have never used anything that would cut through silicone fluid
like VM&P Naptha. Get jar or other suitable container and a tea strainer
to hold the small parts. Thanks to INTEGRA for this tip.
http://www.webstaurantstore.com/stai...FcYbQgodPE5tHw
JsK is offline   Reply With Quote
Old 04-21-2011, 12:12 AM   #4
JoeGuam's Avatar
Brake/parts cleaner, then Dawn soap, lastly blow out with an air compressor. Clean!
MBX6T AB MOD OS.25; AB MOD Picco 28
FLM EXT LCG SAVAGE AB & ERCM Picco .28
HPI BAJA OBR 30.5 AND OBR 57CC TWIN
www.abmods.com
JoeGuam is offline   Reply With Quote
Old 04-21-2011, 12:21 AM   #5
Kent Beal's Avatar
Trader Rating: 65 (100%+)
Lacquer thinner works pretty good or an automotive carb parts dip works even better.
TLR 22 2.0, 22T 2.0, 22SCT 2.0, SCT-E 2.0, BAJA 5T, 4PK and DX18, Visionaire's, Yak 54 3x, Habu, AS3xtra, 350QX, 130x, 180cfx, 450x, 550x, Nano CPs, Slick 3D, Crack laser and Extra 300x 120cc.
Looked up the word "ninja" in the dictionary yesterday, it said " ninja not found", well played ninjas, well played.
Kent Beal is offline   Reply With Quote
Old 04-21-2011, 12:22 AM   #6
Go to your auto repair guy and ask him for some parts cleaner they get from Safety Kleen. Works really good I use it all the time, I just dip all my parts in it for about 15 minutes.
Mugen MBX6T
GrumpyStud is offline   Reply With Quote
Old 04-21-2011, 12:49 AM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Works great! Just make sure you let the Naptha dry completely before re-assembling/filling your diffs as it will dissolve your fresh fluid same as it does the old stuff.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-21-2011, 02:31 AM   #8
I think it was on one of Ryan Lutz's videos that I saw him empty the oil out and then put some really light shock oil in and spun the gears to almost dilute the thicker oil that remained and then empty/drain again etc...
You could then try standing the diffs/gears on some baby wipes as those things seem to attract and absorb the oil really well!
Jaf1977 is offline   Reply With Quote
Old 04-21-2011, 04:30 AM   #9
Guest
Default cleaning
i use weaver break cleaner from advace auto. it doesnt have such a strong smell an drys quick with no left overs.
LOSIRACER77 is offline   Reply With Quote
Old 04-21-2011, 06:28 AM   #10
Qtips - part cleaners and a movie
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-21-2011, 08:12 AM   #11
Just open them up remove gears turn the housing upside down and let stand for thirty minutes on a paper towel, then rebuild. No solvent needed.
donrod is offline   Reply With Quote
Old 04-21-2011, 08:23 AM   #12
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
let it all leak out of case, hit case/gears with motor spray....hit all again with compressed air....done.
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-21-2011, 08:33 AM   #13
motomatt's Avatar
Geez.
http://www.gmksupply.com/html/gmk0112.html
Get one of these.
coffee can with 1/2 pint of gas
Soak for a few, jiggle a 'lil.................repeat.
easy peasy
motomatt is offline   Reply With Quote
Old 04-21-2011, 08:40 AM   #14
this is what i do, got tired of all the brake cleaner and tidius time it takes. take the satellite and sungears, turn the upside down with the diff cup, let sit, wipe off the shims and assemble.
you will get the same results without all the hastle.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 04-21-2011, 08:54 AM   #15
Thanks everyone. I have been just letting it run out on its own, but 125k takes a while lol. I will try a couple new ways and find the best for me. Thanks again
Diff oil & grease cleaner help guss2009 Nitro Off-Road 35 06-23-2012 10:19 AM
diff cleaning sheldon637 Electric Off-Road 23 01-06-2010 01:17 PM
Diff Cleaning Solvent rcgeezer Nitro Off-Road 23 05-22-2009 01:36 PM
How you guys clean diff az00lude Nitro Off-Road 57 08-02-2008 11:06 PM
