Old 04-20-2011, 08:27 PM   #1
SocLiche's Avatar
Trader Rating: 14 (89%+)
Default What do you charge your RX packs at?
I recently charged my 1700mAh RX pack @ 1.7 amps and it started to balloon pretty badly. Did I charge it too high?
Losi 8IGHT 2.0 RR, SAVOX 1267-SG's, Orion MTE - 2013 Pipe
Crushin' it.
SocLiche is offline   Reply With Quote
Old 04-20-2011, 08:35 PM   #2
I charge them at 1C. My 2300mAh lipo stick for THE Car charges at 2.3Amps.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 04-20-2011, 08:36 PM   #3
Torian4000's Avatar
Trader Rating: 49 (100%+)
Not sure but I usually charge mine at 1.2 amps the first time and then I'll charge at 1C from then on out. Maybe you just got a bad pack or your charger's rating is off and allowing more amps than whats displayed.
Torian4000 is offline   Reply With Quote
Old 04-20-2011, 08:39 PM   #4
Integra's Avatar
Are we talkin Lipo, Life, Nimh ?
What kind of charger ?
Old 04-20-2011, 08:48 PM   #5
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
what he ^^^^^^ said... if you charge a lipo on nmh or life settings well poof there goes your pack....
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 04-20-2011, 09:23 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
I'm guessing this is a nimh pack and if it is I wouldn't charge it over 1 amp and more realistically I would charge it at .7-.8amps. It takes a while bit you don't want to overheat nimh cells
Old 04-20-2011, 09:29 PM   #7
dishsoap's Avatar
I charge our stickman 1,600 mah nimh packs at 3.0 amps all of the time when at the track. When home I go with 1.0 amp.
Over a years worth of use and no problems.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 04-20-2011, 09:34 PM   #8
.5 here ,thats right ....you dont want to overheat the nimh cells , should be warm thats the right way
team terribles
mbx5rcr34 is offline   Reply With Quote
Old 04-20-2011, 09:36 PM   #9
endy0430's Avatar
Trader Rating: 25 (96%+)
always charge my at 1.0 without any problems
TLR 22 3.0
Spektrum DX4R Pro
Savox Servo
endy0430 is offline   Reply With Quote
Old 04-20-2011, 09:37 PM   #10
ohh EPiC FAiL's Avatar
Trader Rating: 51 (100%+)
i always charge all my batteries at 1c or a little above and haven't had any problems thus far.
TEAM FEARLESS RACING
I Race: Losi 8ight-E 2.0
I Crawl: XR10(almost VP10)
I Support: Futaba--Holmes Hobbies--Savox--Castle Creations--Tekin
ohh EPiC FAiL is offline   Reply With Quote
Old 04-20-2011, 10:55 PM   #11
merdith6's Avatar
Default Well
1.1 amps for my NiMh reciever packs...at the track 1.2.....I know, I know...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 04-20-2011, 11:01 PM   #12
mr240's Avatar
Trader Rating: 61 (100%+)
Don't matter the type of battery. Either NiMh, NiCd or Lipo. I always charge at 1C.
mr240 is offline   Reply With Quote
Old 04-21-2011, 06:03 AM   #13
REARSPROCKET's Avatar
I use .5 amp @ home and 1 @ the track.
XXXNT/V15T,Menace21,XXXS/Hacker,TMAXX/S18TX,LightningIIPro/S421BS/NX,MiniT
REARSPROCKET is offline   Reply With Quote
Old 04-21-2011, 06:16 AM   #14
Jerm13's Avatar
Trader Rating: 36 (100%+)
The same as what ever the pack is rated. 1700mah charge at 1.7 amps. You can do a quick peak if its already charged at .4-.5 higher buy watch out for the pack getting to hot. Heat will kill a battery no matter what type it is. Theoreticly it should take 1 hour at 1C. But it is hardly the case. At 1C, a completly drained pack will usually only takes about 45-50 minutes at 1C. I only do a peak charge if I plan on running 30 minutes or more. Lipo's are kind of different. If you charge them to much the expand or possibly blow up.
Most of the time a NiMH/NiCD will ballon from physical damage more than from charging it to high. Or if you tried to charge it on the wrong setting ( Lead/Acid instead of NiMH).
Jerm13 is offline   Reply With Quote
Old 04-21-2011, 07:49 AM   #15
awidz's Avatar
i charge at .05 to 1 amp max
awidz is offline   Reply With Quote
LIFEPO4 RX 6.4V BATTERY COBRARACING Nitro Off-Road 277 04-21-2010 02:01 AM
What do i set my charger at to recharge my hump packs ? GASMAN123 Radio and Electronics 6 12-10-2009 07:40 AM
lipo rx pack versus nimh rx pack zixxer Nitro Off-Road 6 11-03-2008 05:23 PM
Maxamps Lipo packs hardrider Singapore R/C Racers 138 10-25-2008 10:35 AM
