Old 04-18-2011, 07:09 PM   #1
deadmancourt's Avatar
Trader Rating: 11 (92%+)
Default What tire and wheels are R.O.A.R approved for truggy?
i need to know so i dont go out and stock up on sets of wheels and tires that i cant run at the nats in june
Rob Schneider
Special Thanks To:
S&W Fuel~Agama Usa/HobbyProUsa.com
RcRenew.com and TritonRc.com~Lucky7~Eazyrc.com
Venom-Group~Upgrade-Rc and TrackstarRc.com
deadmancourt is offline   Reply With Quote
Old 04-18-2011, 07:51 PM   #2
davidfast's Avatar
Trader Rating: 22 (100%+)
There isn't an approved list it has to fall in this:
Wheels:
Mounting Bead Diameter Maximum 95.25mm
Mounted Width Minimum 55.88mm
Overall Diameter Maximum 101.6mm
Tires:
Diameter Minimum 137.16mm
Width Minimum 60.33mm
9.4.4.6 Tire Rules:
9.4.4.6.1 No tires created for other vehicle types even if they meet the specifications will be
allowed.
9.4.4.6.2 Cutting or modifying the tread is allowed. Modifying the tire carcass is prohibited. Trimming the mounting bead of a tire in order to fit a legal rim is allowed. Cutting tires from same class to fit wheels of same is not allowed, regardless if it fits minimum tire dimensions. Cutting tires from one class to another class is not allowed regardless of dimensions.
9.4.4.6.3 All tire measurements reference the carcass dimensions and do not include the tread depth or width. LP tires are referenced for the minimum 1/8 Truck size and measure the absolute minimal diameter allowable in the 1/8 Truck class.
Thanks To:
Maclan Racing / JConcepts / Bubba's Bing / Xpert / R17 / Legit Lids / Bodies By Ed
davidfast is offline   Reply With Quote
Old 04-18-2011, 08:30 PM   #3
jmaxey51's Avatar
i think the only ones that are not are Pro-line VTR but dont quote me on this, i remember seeing or hearing it but i could of been seeing and hearing wrong info
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 04-19-2011, 11:53 AM   #4
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
If you get HB, AKA, TL, JConcepts tires and wheels they will be legal. The PL VTR tires are legal as far as I know, but the PL VTR wheel isn't legal. The PL VTR tires can only be used with the PL VTR wheels, uses 1/8 buggy style bead which doesn't mount to the 'traditional' truggy style wheel beads.
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
V.O.R.R.A. Virginia On-Road Racing Association gentleman81 Mid Atlantic RC Racing 1797 09-22-2016 08:34 PM
MUSIC CITY R/C RACEWAY 56DIRT Oval, Larger Scales and More 75 02-27-2010 05:50 PM
