Old 04-19-2011, 09:53 PM   #16
merdith6's Avatar
Default Cool
Originally Posted by cordarrow View Post
Yes, the outer diff case has far too much room for the bearing to move. I believe it's a necessity to eliminate this.
I use two strips of aluminum tape cut precisely to fit the bearing bed of the outer case. Snugs them up nicely. Two strips should tell you....there's too much room here.
That's a great idea......I would have never thought of that.....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 04-19-2011, 10:13 PM   #17
MugenSeikiPro's Avatar
After reading this took my front gear case off and discovered this:
About 20 tanks in. Looks like the pinion was carving on the differential casing as you can see. Should i add a shim to my gear shaft? Also should i have greased my gears where it is metal to metal?
The grooves on the gears look fine also.
MBX6T - Ninja JX .21
MugenSeikiPro is offline   Reply With Quote
Old 04-19-2011, 10:35 PM   #18
Wow, that looks pretty bad. Does this happen to the mbx6 as well? I took off mine, and found out that my pinion gear does rub against the diff case and leaves pinion teeth marking on it.
dashstryk3 is offline   Reply With Quote
Old 04-19-2011, 10:57 PM   #19
it looks worse than it is...especially after cleaning it. I am sure it is fine.
Old 04-19-2011, 11:24 PM   #20
JBURCH's Avatar
I don't drive a Mugen but no vehicle should look like that. So I wouldn't consider it fine.
JBURCH is offline   Reply With Quote
Old 04-20-2011, 12:18 AM   #21
JoeGuam's Avatar
That damage is caused by the bevel gear not being push/flushed with the joint cup.
MBX6T AB MOD OS.25; AB MOD Picco 28
FLM EXT LCG SAVAGE AB & ERCM Picco .28
HPI BAJA OBR 30.5 AND OBR 57CC TWIN
www.abmods.com
JoeGuam is offline   Reply With Quote
Old 04-20-2011, 12:37 AM   #22
JUD
JUD's Avatar
When I take my car apart, I always install my center drive shaft on first to ensure it is as flush as possible on the bevel gear. Then I install my diff into the case.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 04-20-2011, 03:44 AM   #23
morgoth's Avatar
This is because you CVD probably came loose or was mounted with play. If you mount the cvd on the pinions, you need take out the diff and push the pinion on the diffcase and also the centercup. Then tighten the grubscrew. Don't push very hard, just a little so there's no play.
I can see the teehth in my diffscase because I've had a loose CVD in the beginning I drove this car, but not as worse as your diff case.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 04-20-2011, 05:25 AM   #24
We usually put a diff shim, behind the front bearing of the pinion shaft, then install the pinion shaft, hold the gear of the pinion shaft with my thumb and the center driveshaft universal with 2 fingers, hold then together with pressure, and tighten the set screw on the drivesaft universal. That takes the play out of the pinion and should eliminate what you see in the pictures.
Hope that helps.
BPettit is offline   Reply With Quote
Old 04-20-2011, 09:23 AM   #25
wow thats pretty bad! my diff case doesnt have any marks in it like that just no teeth on half the ring gear and little nubs on the pinions, both front and rear! they are being sent in to mugen later on this week i ordered new front and rear diffs and pinions ( although i dont think i should have too ) an MSPEC is ready to race and set up out the box. this is like the 4th truck i have seen at my track have this happen too. I love my mugen but durability has always been an issue.
stuntryda is offline   Reply With Quote
Old 04-20-2011, 09:34 AM   #26
This isn't m-spec. I bought the kit. For a first timer I would say that the instructions are partly to blame. They are so vague and leave a lot of guessing to finish the job. But durability? You kidding. The Mugen is probably the most durable truggy. This is probably my fault since I built it and the other 3 trucks you seen were probably built as well. I will talk to mugen today
Old 04-20-2011, 10:23 AM   #27
You HAVE to HOLD the pinion and universal cup TOGETHER while you tighten the grub screw, or this is what happens!
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 04-20-2011, 10:49 AM   #28
Thanks. I just called Mugen and you said the same thing they did Time to take it apart. I shouldn't have to replace it right? Its probably half a millimeter deep groove and the case is a very strong plastic.
Old 04-20-2011, 11:36 AM   #29
It's fine. Sand the rough edges off the cup though
Mugen
Old 04-20-2011, 05:37 PM   #30
cordarrow's Avatar
Trader Rating: 17 (100%+)
I put one strip in the bed...then take a bearing and seat the tape really well, generating some heat...then add the other.
There's just enough room for two strips of you rub them in really well....
cordarrow is offline   Reply With Quote
