Old 04-17-2011, 01:54 AM   #1
Trader Rating: 3 (80%+)
Default loctite which one
Sorry not sure if this is in the correct section
Bit of a newbe question
Is Blue loctite what i should be using to stop screws becomming loose or should i use Red?
Does it effect the plastic used on Losi's
Thanks all (sorry if this in in the wrong section)
sbv20j is offline   Reply With Quote
Old 04-17-2011, 02:02 AM   #2
Keep in mind Locktite is a brand name. Blue for any metal to metal. Red if you never want it to come apart. Try super glue(another brand name) for the plastic stuff.
The Working Man is offline   Reply With Quote
Old 04-17-2011, 02:34 AM   #3
Nitro2002's Avatar
Green Locktite has worked fine for me too. Use either blue or green.
Never use red, it will permanently lock the screws.
Nitro2002 is offline   Reply With Quote
Old 04-17-2011, 12:08 PM   #4
Send a message via AIM to insane4speed
Well that answers my questions bout which one to use
insane4speed is offline   Reply With Quote
Old 04-17-2011, 12:26 PM   #5
Buy blue but get it in glue stick form its much easier to work with.
misasi is offline   Reply With Quote
Old 04-17-2011, 01:50 PM   #6
JamminSP's Avatar
If the screws coming loose are threaded into plastic then try a little drop of CA (super glue). Locktite works best on metal to metal.
Shawn Powers
::Special Thanks to My 2014 Sponsors::
Imbue Motorsports, Radiosistemi, RW Mods, Argus Engines, Radiopost
R.I.P Matt "Reaper" Powers 09/24/1953 - 10/24/2013
JamminSP is offline   Reply With Quote
Old 04-17-2011, 03:28 PM   #7
portyansky's Avatar
Trader Rating: 54 (100%+)
If using CA glue into plastic, make sure it starts to gum up a little before using it.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
ZD Racing/MRC ZRT-1 toast after one run... CRed Electric Off-Road 57 05-08-2011 11:17 PM
What color Loctite and where ? sidewaze Nitro Off-Road 27 06-30-2008 09:44 AM
Which r/c is best for me? JohnnySplat Electric Off-Road 12 05-05-2004 06:26 PM
