Old 04-16-2011, 03:51 PM   #1
Default Driving a nitro buggy
Just picked up a RC8B from the forum here. I have never driven a 1/8 buggy before. Last ngiht I went out and ran about a tank through it. Had some help from the local guys. Night and day from the SC10
I know the obvious answer is to drive it, but for the next several weeks I will be slammed with very little time to get to the track
the problem is driving my 2wd electric is so engrained in my brain, Im doing all the wrong things with the buggy.
I noticed hitting the brakes and steering around the turns doesnt work so well, I almost have to mash the brakes then floor it around the turns to swing it around.
just looking for basic tips, the major differences in driving a 4wd buggy vs 2wd truck. What not to do etc.
also, I noticed it spun around very easily, like my SC10. is this because the front diff oil is too light? seemed almost like most of the powder/traction was in the rear.
Hemi Killer is offline   Reply With Quote
Old 04-16-2011, 04:11 PM   #2
Charles Godwin's Avatar
Rebuild it and makes sure nothing is binding for starters. Go to a smoother clutch by using 0.9mm springs to make it easier to control on acceleration. Play with the brake settings. Generally having more rear brake will give you more steering into the corner.
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 04-16-2011, 09:24 PM   #3
VWVR6_T's Avatar
Send a message via MSN to VWVR6_T
Do some reading in the AE thread, I'm sure you will learn even more about this buggy.
TLR 8ight 2.0 - Werks B5/2058 l Airtronics l Hitec l rev-rc.com l Werks Fuels l Sweep
TLR 8ight T 2.0 - Werks B5 Pro/2013 l Airtronics l Hitec l rev-rc.com l Werks Fuels l AKA
Ofna GTP l Hyper 8P Turbo
QUOTE by FLHX1550 "The Werks B5 is kind of a legend"
VWVR6_T is offline   Reply With Quote
Old 04-17-2011, 02:08 AM   #4
Man, once you get the hang of it, running 2wd and going 4wd is night and day. After you get the set-up down, it's like driving on rails.
The Working Man is offline   Reply With Quote
Old 04-17-2011, 08:54 AM   #5
Ill check out that thread, theres a lot to read in there
it seems like this car was setup for a small tight track, which mine is not.
the manual was included, I may just tear it down and set it up how I want
thanks for the advice.
Old 04-18-2011, 07:01 PM   #6
Trader Rating: 30 (100%+)
Put the right tires on it. Then point and shoot!!!
Axial Wraith
sdtech58 is offline   Reply With Quote
Old 04-24-2011, 07:53 PM   #7
aray's Avatar
I would rebuild and put a starting setup on it, Associated is great for that since there are lots of setups available.
Brandon Melton put together some great videos for tips on building the car, it's definitely worth a watch. http://www.youtube.com/watch?v=u-pyUz5yQyQ
Once you rebuild with a decent setup, then you can start to play and change things... but it's hard to tell which way is up when you don't know where you started.
IMHO - Generally you should be able to set the car up to drive however you like. Smooth electric throttle fingers probably will be an asset as well.
aray is offline   Reply With Quote
ThE BoYzz and TheIr ToYZzZ!(nitro buggy/truggy) tony510 Manila Racers 2550 05-02-2016 04:40 AM
1/8 nitro buggy to 1/10 electric 2wd to improve driving skills dishsoap Electric Off-Road 34 02-27-2010 04:36 AM
Good cheap nitro buggy? ryanroma Nitro Off-Road 24 08-26-2008 04:39 PM
Recomend me a Nitro Buggy/truck D4nny06 Nitro Off-Road 20 06-18-2007 01:11 PM
