losi 8ight 1.0 4 clutch shoe/spring combo
I've been outta R/C for awhile now and over the past 2 years I've work on my dad's old losi 8ight 1.0 he took apart. He bought various springs and shoes for and told me that there's a combo to use for maximum performance but neither of us know what it is. Little help please?
Suspended
performance
is there a difference in performance? like between the springs or shoes?
Also, the stiffer spring will engage later (higher engine speed) and therefore will be punchier, but more difficult to control on loose surfaces.
Mixing spring weights and shoe materials allows 2 shoes to grab slightly before the other two, giving a more progressive clutch engagement.
I run 2 ally shoes with gold springs, and 2 plastic shoes with green springs. Thats for a dirt track with fairly loose surface.
Suspended
IMO some of the best! Just have to file down the burrs after a race day, they last a LONG time!
http://www.amainhobbies.com/product_...ch-Shoes-Set-4
theres a set up i wanna run (for tires) i forget what its called cuz like i said no one around me has talkd about R/C in awhile all i know is adam drake ran it at one point it uses i think bow ties in rear for max push and then somethin in the front that gives you a bunch of side bite for max turnin if i find the front tire ill tell you what it is my dad told me it was too aggressive of a set up for him though and i watchd him pushin way too wide through the corners
my only problem for about EVERYTHING is i havent raced in awhile so idk if im gonna want/need more top end or low end so itll be kinda tough
Suspended
we had been at action hobbies that night it shut down though its a short track, well maintained, dirt was wet (but not puddled) and i think it was just a smooth well groomed dirt dont rly kno how else to describe it
