Old 04-12-2011, 06:31 AM   #1
endy0430's Avatar
Trader Rating: 25 (96%+)
Default Boca VS Avid
First time changing my bearing and wanted some help choosing the better kit.
http://www.bocabearings.com/bearing-...uggy-1/8-scale
or
http://www.avidrc.com/flexkit/?kit=245&kitname=D8
Thanks if anybody have used either one please help with pro's and con's.
TLR 22 3.0
Spektrum DX4R Pro
Savox Servo
endy0430 is offline   Reply With Quote
Old 04-12-2011, 06:38 AM   #2
or
I use both, dont have problems with either. I lean more towards Avid tho
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-12-2011, 07:07 AM   #3
ScottyM's Avatar
Trader Rating: 27 (100%+)
For engine bearings BOCA cannot be beat. For general (8x16) bearings either will be good, and I doubt 1 will out last the other.. Another good brand is Ready Rollers Bearings..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 04-12-2011, 07:25 AM   #4
pickle311's Avatar
Trader Rating: 31 (100%+)
I've used both and I prefer Avid. I don't know if it's just me, but it seems that the seals are a little better on the Avids. It's taken them a lot longer to get gritty.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 04-12-2011, 07:47 AM   #5
Ruune's Avatar
Send a message via ICQ to Ruune Send a message via AIM to Ruune Send a message via Yahoo to Ruune
You'll get comparable performance out of both. Make sure whatever you get has a rubber seal. Avid has the revolutions, where it has a rubber seal that's on the exposed side, and a metal shield on the unexposed side. These are great. Boca uses rubber seals on both... which is just as good. just a matter of preference. You dont need to go ceramic on your diffs, etc, unless you're trying to squeeze out a few extra seconds of runtime. As you progress, this may become more important. As far as engine bearings, a good ABEC-5 Rated ceramic hybrid (ceramic balls w/ steel rings) rear bearing and a double-sealed front steel bearing (also ABEC-5) is going to give you the best bang for your buck.
The most important thing is to keep the bearings as clean as possible (inside and out), but also to keep them properly lubed. Check them intermittently by putting spinning them with your finger(s). If they feel grainy, or it sounds like they have sand in them, try flushing them with penetrating lube, dry them (air compressor), then use a good bearing lube or dry lube. I do the same for CVDs. If your bearings continue to feel grainy or inconsitent when turning them, just replace them. At approx $1 a pop (avid revolutions), it's cheap insurance. Good, consistent bearings will have a dramatic effect on drivetrain power delivery to each corner.
Ruune is offline   Reply With Quote
Old 04-12-2011, 08:46 AM   #6
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
+1 Ruune
Avid all the way.
We support those that support the hobby!
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 04-12-2011, 11:21 AM   #7
omarwashington's Avatar
For me, Boca for engine bearings, Avids for chassie and clutch bearings.
RCCARS!
omarwashington is offline   Reply With Quote
Old 04-12-2011, 12:15 PM   #8
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I used to run the Boca Orange Seal Ceramics in my 8th scales. $320 a set. They were amazing.
But they were $320
I now run Avids, the only difference I see is longevity. But-$320<$25
Why is this hobby so full of drama? Its toy cars....
Dlewis4 is offline   Reply With Quote
Old 04-12-2011, 12:33 PM   #9
But they were $320
Really $320 for miniature bearings for a toy? Dang Bud...... Ballin!
Old 04-12-2011, 12:38 PM   #10
Dlewis4's Avatar
Yes-I know. I won't ever do that again though
They were awesome "space age technology" blah blah blah. I never had to touch them, which was nice, but.....so is $25
Old 04-12-2011, 12:49 PM   #11
neobart's Avatar
I like Avids, mostly because their page is easier to navigate.
I never buy the kits either. I don't go through diff bearings at the same rate as I go through wheel bearings.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 04-12-2011, 01:01 PM   #12
Boca Bearings here. Ceramic Lightning Yellow Seal are great about 100 bucks. Their standard start around 20 bucks, both a full set for buggy/truggy. What makes the yellow so good is they are lubed for life. I think they are right close to being ranked with the 300 orange seal bearings at a third the cost.
Even Boca standard are great, just require more attention while being used.
Im the wrench man
Boca Bearings~Pro-Line Racing~Radiopost~VP Pro USA
RcRacer37E is offline   Reply With Quote
Old 04-12-2011, 02:05 PM   #13
NITROALM's Avatar
Thumbs up
Shout Out to David at Avid!! we use them in all of our test vehicals
and I think its safe to say Donnie/Dylan Rodriguez put them to the Acid test
while testing and Racing. the results speak for them self++
And of corse not to mention David is a Ace driver, Always looking to better
his Parts line up at Avid+++ Keep up the Great Work David
NITROALM is offline   Reply With Quote
Old 04-12-2011, 02:19 PM   #14
Pit-racer's Avatar
I choose and use AVIDS on all my vehicles(toys).
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 04-12-2011, 02:33 PM   #15
Thanks Bill, we use the AVID in all our cars and rebuilt motors, we also use the fiber brake disks that shave a 1/2 oz of rotating mass from your drive train. Good stuff
donrod is offline   Reply With Quote
ceramic bearings vs regular? rcdude236 Nitro Off-Road 16 06-14-2010 04:43 PM
AVID vs Ready Rollers Bearings!! KWT-NITRO Nitro Off-Road 64 04-22-2010 06:09 AM
Ceeramic VS Xray Ultra highspeed berrings wiscnitro Electric On-Road 7 05-22-2009 07:17 PM
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 08:38 AM
