Old 04-11-2011, 12:29 PM   #1
Default losi 8ight 1.0 4 clutch shoe/spring combo
I've been outta R/C for awhile now and over the past 2 years I've work on my dad's old losi 8ight 1.0 he took apart. He bought various springs and shoes for and told me that there's a combo to use for maximum performance but neither of us know what it is. Little help please?
raddracer1278 is offline   Reply With Quote
Old 04-11-2011, 12:34 PM   #2
Suspended
Trader Rating: 202 (96%+)
i like all aluminum shoes, 2 with green springs and 2 with gold
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 04-11-2011, 12:45 PM   #3
Default performance
is there a difference in performance? like between the springs or shoes?
Old 04-11-2011, 06:22 PM   #4
tomdex's Avatar
Trader Rating: 4 (83%+)
Yes, running all aluminium shoes will give more punch than running 2 ally, 2 plastic.
Also, the stiffer spring will engage later (higher engine speed) and therefore will be punchier, but more difficult to control on loose surfaces.
Mixing spring weights and shoe materials allows 2 shoes to grab slightly before the other two, giving a more progressive clutch engagement.
I run 2 ally shoes with gold springs, and 2 plastic shoes with green springs. Thats for a dirt track with fairly loose surface.
tomdex is offline   Reply With Quote
Old 04-11-2011, 06:27 PM   #5
How long do your tires last?
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 04-11-2011, 06:39 PM   #6
Suspended
All year, our track is loose (real dirt), very little wear on tires, my sets from last year still have 90% tread left
Old 04-11-2011, 06:45 PM   #7
hum interesting, Im looking at trying 4 alum in my buggy and was trying to figure out springs
Old 04-11-2011, 06:49 PM   #8
Suspended
depending on engine performace, black and gold work well in buggy. right now im running green and gold with aluminum shoes in both truggy and buggy with steel flywheel
Old 04-11-2011, 07:24 PM   #9
Suspended
IMO some of the best! Just have to file down the burrs after a race day, they last a LONG time!
http://www.amainhobbies.com/product_...ch-Shoes-Set-4
orijen is offline   Reply With Quote
Old 04-12-2011, 05:06 AM   #10
theres a set up i wanna run (for tires) i forget what its called cuz like i said no one around me has talkd about R/C in awhile all i know is adam drake ran it at one point it uses i think bow ties in rear for max push and then somethin in the front that gives you a bunch of side bite for max turnin if i find the front tire ill tell you what it is my dad told me it was too aggressive of a set up for him though and i watchd him pushin way too wide through the corners
Old 04-12-2011, 05:10 AM   #11
my only problem for about EVERYTHING is i havent raced in awhile so idk if im gonna want/need more top end or low end so itll be kinda tough
Old 04-12-2011, 07:53 AM   #12
Suspended
what are you track conditions? clay, loomy, dry, wet,...ect
Old 04-12-2011, 10:56 AM   #13
we had been at action hobbies that night it shut down though its a short track, well maintained, dirt was wet (but not puddled) and i think it was just a smooth well groomed dirt dont rly kno how else to describe it
Old 04-12-2011, 11:36 AM   #14
Suspended
lot of guys here run Ibeams in the rear and cityblocks in the front.
Old 04-13-2011, 12:01 PM   #15
Trader Rating: 30 (100%+)
Steel Flywheel. 4 Max-Life Aluminum Shoes. 2 green and 2 gold.
Axial Wraith
sdtech58 is offline   Reply With Quote
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
