Old 04-10-2011, 03:46 AM   #1
ted05's Avatar
Default Team Associted CVA Problem ,,pls HELP
hi guys i just got my RC8B FT buggy,,,, the problem is the front CVA keep bending all the time ,,,,i have to take it out and knock it with hammer ,,,
is there any other buggy CVA that i can use ???? pls help me on this thank buddys
ooooooooooooooo
ted05 is offline   Reply With Quote
Old 04-10-2011, 08:47 AM   #2
ronsand's Avatar
This is a common problem on the RC8. As long as everything else is built and adjusted properly you can try to reduce the epa (end point adjustment slightly).
Check that you are not using excess droop.
Have the car at normal ride height with arms about level. Adjust epa to where it starts to bind (steering block against C-hub) and then back it of somewhat (do the same for both left and right of course).
Check that there is no binding in the steering linkage, during the full suspension travel, as you turn the steering.
You can in addition, as mentioned in an other similar post, dremel of a mm or so from the end of the dog bones.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
