Old 04-03-2011, 01:46 PM   #1
Default RC8B braces a bit too long
Hi everyone, I'm building a RC8B kit and I notice that the front n rear plastic braces are about 1mm too long. I could kinda force them in and they will fit but they really push the shock tower assy out that the factory pre-cut holes on the body would not line up any more so that kinda tells me there might be something wrong here.
Any similar issues for those that had a chance to build one of these things?
thanks
mk74 is offline   Reply With Quote
Old 04-03-2011, 02:18 PM   #2
Lilja's Avatar
No I also had to bend the cassis just alittle to get them in so its not a perfect fit.
About the body you should make the back hole a bit wider to front and back to allow the chassis to flex, otherwise it will crack the body around the hole.
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 04-03-2011, 04:36 PM   #3
dragracechief's Avatar
Mine were definatly a tight fit but nothi ng to worry about, kinda like preloading the chassis a bit.
dragracechief is offline   Reply With Quote
Old 04-04-2011, 06:35 PM   #4
I'm about to try a set of these:http://www.amainhobbies.com/product_...-Set-Front-RC8
Old 04-04-2011, 08:48 PM   #5
I haven't used those much but from what I have seen those flex quite a bit and have a tendency to pop off the balls, at least on the truggy.
Old 04-04-2011, 09:29 PM   #6
Maan.. always sumthin.. lol
Old 05-14-2011, 10:35 PM   #7
well the rear plastic brace didn't last more than several runs. it snapped at the bottom mounting hole and the body got all messed up from excessive chassis flexing.
So I got the FT alu and that one fit much better. I just had to bend the chassis back to straight to make it fit.
Old 05-15-2011, 01:30 AM   #8
Lilja's Avatar
Yes the braces on the AE cars arent exactly the best. Ive cracked several both front and rear braces on both my cars. Moved to aluminium and then the screws cracked instead.
Futaba 4PK
Old 05-15-2011, 03:13 AM   #9
I've never broke them what are you doing to break them?
pdmustgt is offline   Reply With Quote
Old 05-15-2011, 03:41 AM   #10
Lilja's Avatar
Driving it
You cant really do more than just put them on and drive. Thing is, the way theyre mounted, the M3 screw takes all the force of the chassiflex when you land after a jump or you crash into something.
Youre lucky if you havent broken any, I know alot of people that havent, but it doesnt make it a good design.
Futaba 4PK
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
