Old 03-31-2011, 09:23 AM   #1
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Default how many shims in the diff? 8ight t 2.0
Hey guys, i have a 8ight t 2.0 and i need to put the shim kit in the rear diff still. How many shims have you guys found is about right for the rear diff? Or how tight should i get it? I just have a heck of a snap sound when it takes off from a dead stop and i have been told that's cause of loose diffs. Thanks!
Kyle
Mugen MRX5 - Ielasi Modified Engines/Matrix Tires/Savox Servos/Airtronics Radio
IGT Hobbies - The one stop shop for anything on-road and incredible customer service.
brothainchrist0 is offline   Reply With Quote
Old 03-31-2011, 10:38 AM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
Kyle
Start with 2 on each side then put the rear gearbox set together fully and tighten the screw and check the mesh.you want it tight to where there is no backlash on the gears and. there will be a high spot to where its rough to spin over it.the diff will break in and the high spot will smooth out over time.but you gotta keep checking it and make sure your diff mesh stays tight.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 03-31-2011, 10:47 AM   #3
Thanks man! I'll start with that. And what should i feel? by backslash, u mean absolutely no play? should there be a little tick in it like the gear mesh between the spur and pinion gears? Thanks. this is the first diff i have had to put shims in.
Old 03-31-2011, 05:27 PM   #4
crotty777's Avatar
Yes shim it tight, no play, they will work in.
*Dialed RC Hobbies, Windwater RC, Kustom Kolors, HRP, Sweep Racing,
RC Concept*
crotty777 is offline   Reply With Quote
Old 03-31-2011, 05:38 PM   #5
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
I've had upto 7 shims in mine.
The box streaches over time and you just keep adding shims
I also found that sometimes the standard amount of shims wasn't giving me the right mesh so jamming another one in and attracting the box a little gave me the perfect mesh
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 03-31-2011, 06:07 PM   #6
dburt86's Avatar
is this the case with most truggy diffs?
dburt86- xbox live
dburt86 is offline   Reply With Quote
Old 03-31-2011, 06:21 PM   #7
crotty777's Avatar
no not usually, thats what nice about the losi diffs. most other truggys use spiral cut gears which on one hand are a lot smoother, but are much more critical on gear mesh.
RC Concept*
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
Losi 8ight T 2.0, Futaba 3PKS, Hyperion, AKA, Novarossi, Hudy, AMB, tools looneytune R/C Items: For Sale/Trade 27 01-04-2010 04:35 PM
