Old 03-27-2011, 11:38 PM   #1
Default diff??
my xb8 ..i took for a bash the other day and it juts did doghnuts...as tho it was rear wheel drive..drive shafts are still connected and u spin one wheel they all spin.. what gives?
boomtheroom is offline   Reply With Quote
Old 03-28-2011, 01:16 AM   #2
speedy2's Avatar
first you should open the diffs, to see if some oil is still in it..
do the wheels spin freely when you turn them on one axle, fr or rr
does the center diff spin if you keep the front wheels on the ground
and spin both rear wheels ??
if you mount new oil, try 3000/3000/5000
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 03-28-2011, 01:30 AM   #3
yes.. but if i just spin either the back left or right on one axel the opposite back wheel moves very slowly compared to if i spin the fornt ones by themself
Old 03-28-2011, 01:49 AM   #4
speedy2's Avatar
from what you are saying, seems no oil is left in the rear diff
you have to check all of them
Old 03-28-2011, 02:18 AM   #5
or is it because its got 1000 in the rear and 7000 in the front?
Old 03-28-2011, 03:53 AM   #6
speedy2's Avatar
could be..
but in any case the xb8 likes the oils I told you..
so not 7000 fr/1000 rr
Old 03-28-2011, 03:54 AM   #7
j_blaze14's Avatar
Trader Rating: 34 (100%+)
loose center front cvd at the grub screw?
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 03-28-2011, 05:12 AM   #8
aussies1129's Avatar
Trader Rating: 74 (100%+)
easy one all your power is going to the rear check your drive line from the centre diff through to your front universals and that includes opening up your front diff, but it sound like your front drive shaft is spinning on the pinion or you have blown the front diff. its no biggy just check it out its a quick fix
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 03-28-2011, 06:07 AM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
Does it bind or spin smooth just at different rates? Cod have something to do with the cb bearings too. Take the engine out and see how it spins.
Old 03-28-2011, 07:20 AM   #10
Default bearings
this happend to me and it was shot bearings on both sides of the dif thus the pinion was not grabing when torq was aplyed
impetus is offline   Reply With Quote
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1710 08-26-2015 04:39 PM
Spec-R Gear diff review P.I.M.P Electric On-Road 890 08-31-2013 04:16 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Spool vs Diff vs One-Way CRASH Electric On-Road 62 07-21-2011 07:40 PM
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 07:49 PM
