Help setting up servo saver on losi 8t 2.0 RTR please!
hey guys i know there is something wrong with my servo saver and would like to know how everyone does it. i've broken a few metal gear servos in the couple weeks i've had this used truggy. is there any way to feel if it is working ok? is there an easy way to tighten/loosen the nut? any help in setting this thing up will help very much.
ps: i notice my front wheels shaking side to side a lot under hard acceleration out of a turn. does a poorly setup servo saver have anything to do with it?
Suspended
Did you check the bearings in the steering assembly? They could be siezed up and causing the problems with the servos getting all #$%^$# up. There should be a big nut with a spring below it thaat looks like a threaded shock preload adjuster, clockwise tightens it up and counter clockwise loosens it up. I would check the whole assembly first and then go from there. Hope this helps.
Philip
Philip
